Thread: Soften reflections per surface ?
    I know there is a Soften Reflections plugin with LW, but its global.
    Is there a way to soften reflections on a per surface level ? I have a car to do and parts of the body need soft reflections whilst the others do not.
    thx
    F1Racer
    http://www.racingrenders.com
    Intel i7-930 @4.00Ghz | Gigabyte X58A-UD5 | NVidia 480GTX | 12GB 1600mhz | 2TB HDD total | Dell 24" Ultrasharp 1920x1200 | Win7 Ultimate 64bit | ADSL 20mb / 1Mb
    I am Jack's cold sweat Karmacop's Avatar
    Bathurst, NSW, Australia
    2,117
    In lightwave 8:
    In the surface editor under the environment tab there is a reflection bluring amount (below image seam angle)
    In Lightwave 9:
    Use the reflection node (under shaders>reflection)
    Quote Originally Posted by Karmacop
    In lightwave 8:
    In Lightwave 9:
    Many thanks, Karmacop. Now I`ll go put my brain back in
    F1Racer
    Dec 2004
    London
    4,502
    Please note that real blurred reflections render very slowly. The image filter is much faster, but also much less accurate. You can limit the image filter to specific surfaces using the special buffers.
    Are my spline guides showing?
    thanks for that tip Captain. Got that noted.
    F1Racer
    Dec 2004
    London
    4,502
    One thing you could do is use a relatively low number of samples for the blurred reflections, and then use the reflection blurring image filter to smooth out the noise.
