Thread: Elevation map in ASCII Format
    Back from Monkey Island Weetos's Avatar
    May 2003
    France
    943
    Hey there
    I've been ask to model a square of terrain from XYZ ASCII file (the X/Y coordinates and elevation (Z) are written in plain text in an ASCII file). The problem is that I need a grey scale image map instead that I could use as a displacement map. Is there any plugin or tool that can convert those XYZ files?
    I thought the guy that gave me the ascii file could make the conversion himself using his GIS software, but it seems it only outputs dithered (one bit) greyscale images
    Thanks for any help
    Running at 29.97 fps Titus's Avatar
    Mexico City
    2,839
    If you can export your data to DEM you have options to import that file into LW.
    Dreamer MooseDog's Avatar
    Mount Whoville, VT
    1,438
    does this link help:?
    http://www.newtek.com/forums/showthr...ighlight=ascii
    look at the bottom of this one too for xyz2dxf:
    http://www.mt.nrcs.usda.gov/technical/eng/software.html
    good luck
    We are pirates, we are artists...
    Blog
    May 2003
    France
    943
    Thanks guys for the suggestions.
    Titus: Yep DEM seemed to be the way to go
    MouseDog : Thanks ! those are pretty useful !
    Actually I found something interesting that did the trick for me. it's a free tool called 3DEM which can generate color and displacement map from any kind of elevation data, and it my case it helped a lot !
    here's the link : http://www.visualizationsoftware.com...downloads.html
    and here's the result I got :
