Results 1 to 10 of 10
Thread: Toaster with Max and Maya?
    Being that I have not been using Lightwave previously, I'm just
    curious how well other 3D packages integrate into the Toaster
    and what sort of Learning curve is needed for Lightwave.
    One more question....
    What is the difference between the version of Lightwave in
    the Toaster as opposed to the full version?
    Thanx
    19,330
    In a nutshell, it might be said that LightWaveExpress is the version for video clients, designed to make it easy to do common tasks like 3D FLying Logos (and lots more too.) The full version, on the other hand, contains a much larger set of tools oriented toward character animation.
    So - want to to add some good-looking 3D glitz to pretty up your video project without a substantial learning curve, Express is fine. If you're an animator and want to do the next Jurassic Park, you want the full version.
    Dec 2002
    San Antonio, TX
    3,830
    Re: Toaster with Max and Maya?
    At the moment, LightWave Express, LightWave 3D 7.5 and 3ds max all make use of Toaster's NTSC hardware output buffer.
    Don't stream it - TriCast it!
    australia
    8
    who do you get the toaster output from max to work? usually you can select a frame buffer card in max but toaster is not in the list
    thanks
    Dec 2002
    San Antonio, TX
    3,830
    The option is taken care of when you have the Toaster card search for, and configure, 3rd party applications.
    australia
    8
    i can save out rtv files from max and toaster added a rtv.bmi to my max plugins but i cant work out how to frame buffer from max
    thanks
    again
    Dec 2002
    San Antonio, TX
    3,830
    thanks
    again
    Once max is launched...right click on a Switcher patch tag; is max one of the input options?
    australia
    8
    when i check the inputs on the swatches there is no 3dsmax listed as an input i checked the 3dsmax plugin manager it has loaded the rtv.bmi plugin ok so i dont know what else to try and i have just done a fresh install of win2000 and toaster and max
    i am also using 3890 build of toaster
    thanks
    arthur
    Dec 2002
    San Antonio, TX
    3,830
    Arthur,
    You need to specify “render frame on output” in the RTV config area.
    australia
    8
    great working like a charm thanks for all your help
    arthur
