Results 1 to 14 of 14
Thread: TrueLoad v1.0 - tool to preview in OpenGL 3d models before loading!
    7,723
    Hello!
    TrueArt has made and would like to show you the new plug-in called TrueLoad.
    It's tool that could be used in both Modeler & Layout to show in the real-time OpenGL instant refreshed preview of 3d models that you wanna to load to scene or to modeler.
    Video available on our website shows objects made by William 'Proton' Vaughan. Thank you very much Proton for sharing with us your hard work!
    http://trueload.trueart.eu
    Promotional price will be only to 1 May 2006!
    Best Regards!
    LightWave Plugins
    7,723
    New experimental user-interface look..
    How do you like it?
    Because it's enough space for both File and Hierarchy tab, they will be probably integrated soon to save clicking tab to allow you select just part of scene|object..
    LightWave Plugins
    7,723
    New modern layout of TrueLoad..
    Clicking on Hierarchy Tree-List obviously restricts what is displayed in OpenGL.. So you can see what contains each layer.. After selecting .lws scene file in Directory Tree-List more advanced Hierarchy Tree-List is created that contains Objects sub-group, with each object with it's Layers, Surfaces, Parts etc. that could be expanded and viewed independently.. You can load object layer of scene that you have no idea where it's really located on the disk, just by traversing .lws hierarchy..
    LightWave Plugins
    Defender of Mankind Emmanuel's Avatar
    Germany
    1,079
    does it show polygon models only or SDS-objetcs, too ?
    Bye,
    Emmanuel
    For Hire
    Portfolio
    Graveyard Dogs Indie game dev blog, visit and vote for the best RPG of all time !
    7,723
    Quote Originally Posted by Emmanuel
    It shows Sub-Patch cage as polygons.. LW SDK does not have exposed functions to calculate Sub-Patches by 3rd party plug-in..
    The latest improvements: 200% speed increase (and much faster than LightWave native OpenGL already), Animate can be now started/paused by pressing space key, Grid can be turned on/off by pressing 'g' key, restricting display to selected element in hierarchy like surface (see below), or part, fixed Flat Shade preview mode, a lot of fixes in the entire plug-in..
    LightWave Plugins
    Jul 2004
    Los Angeles
    254
    Quote Originally Posted by Sensei
    Actually, Layout plugins can get subpatch information using the meshInfo() function of the Object Info global, with frozen set to true. I've used this in my own internal preview plugin.
    The catch is that you have to manually compute the vertex normals.
    Germany
    1,079
    Well, without SDS-preview, the plugin unfortunately isn't of much interest to me.
    Bye,
    Emmanuel
    For Hire
    Portfolio
    7,723
    Quote Originally Posted by ColinCohen
    True, but when TrueLoad works there is not yet objects loaded by LightWave to Layout nor Modeler! It loads everything using it's own functions, parsing .LWS and .LWO, and generates optimized OpenGL preview..
    We'll try to reproduce SDS in future, because it'll be needed in other projects, but say "thank you NewTek".. LW SDK should be a long time ago enhanced by Polygon Handler evaluation functions.. We need it badly in either EasySpline and VirtualMirror as well..
    LightWave Plugins
    Sensei, is the LW9 SDK structured in the same way? If so, we need some LOUD banners and we shall converge on Texas
    ps Decent Plug
    Brent
    7,723
    Quote Originally Posted by T-Light
    Of course.. Changes are between 2-4%, I would tell.. Similar to what videos presented: edges (wait for EasySplit with support to edges!), camera, node editor..
    LightWave Plugins
    I would really be interesten in stand alone viewer..but it must have texture replacement... for example.. I would like to preview the same part of the object with different texture that I can chose from special folder.
    must have camera pan, rotate, and zoom in/out (not at the origin)
    if you are making this plugin, consider this, if not.. I ask anyone that knows this kind of viewer to post a link.
    thanks.
    oh... and absolutley no statistic, dirs, or other info for the object...
    only:
    object name (witch can read special folder and display all object in that folder) with option to select it for preview
    surface names
    and surface texture (with browse option for selection different texture). or better yet, preview of all avaliable textures for that surface (wich mean special folders for every surface.
    Wow, great 3d modeling program! I like it a lot, won't any of you have the most updated version of it?
    Passionate about 3D modeling and impressions of that kind, visit my website: https://www.stlfinder.com/
    Is there a way to simply add a preview in the native load object Layout window ?
    Eddy Marillat - PIXYM
    WS : MB ASUS X299-Pro/SE - i9 7980XE 2,6ghz 18C/36T - 32GB Ram- 2 GTX 1080 TI - Win 10 64
    GPU Net Rig : MB Biostar - Celeron 2,8 ghz 2C/2T - 8GB Ram - 2 RTX 2080 TI - Win 7 64
