Results 1 to 10 of 10
Thread: Some improvement to LW8 or what I would like to see in "PROJECT MECCA"
    Talking Some improvement to LW8 or what I would like to see in "PROJECT MECCA"
    hi all.
    I don't know what's happen at luxology. If lux guys be working in lw8 or another 3d packet (I heard about MECCA) or don't.
    I really would like see LW8 or project MECCA get this improvement . I think you guy would like too.
    :: Option to use "along normal" as move and rotate points and polygons, and every possible tools to use it. (there is a plugin to move point along normal)
    :: Add Edges
    :: 3D paint
    :: Virtual Mirror to perfect symmetry (like Mirai and Wing3d). LW symmetry have some bugs.
    :: Sub-pacth with suport to >4 points
    :: Improve UV to work better with Sub-Ds
    :: Viper with suport to UV and weights
    :: Improve particle system to work fine with liquids and smoke inside another objects.
    :: Possibility to pause render like After FX and a display to show render progress (who have 1 PC only. knows what I mean)
    :: More UNDOS to layout
    :: ADD Edgetools, Edgebevel and Quicksaw to modeler
    As more easy I make a composition in viewport as speak english.
    Here is some images. I think that will fine LW or LUX project come with it.
    EXECUSE MY POOR ENGLISH
    V a l t e r . S i l v e i r a
    3D Artist - Editor
    http://valtersilveira3d.blogspot.com
    Detail of viewport
    3D Artist - Editor
    Some things I want to add :
    -Highlight selection faces ( very often i havn't selected all the faces i want )
    -2 little sliders for clipping planes ( near and far )
    -Switch for grid snap settings...If there's no better Autosnap ( on the Fly ) tools ( ā la Rhino or AutoCad)
    -A little toggle for the perspective viewport for switch between differents user's points of view (because we have no cam in modeler )
    -Same thing for lights--> switch between differents lighting setup.
    Awesome stuff Valter.
    Yes, very needed, indeed. But a marker dropdown would be better. To keep it clean.
    Chris Burkert
    ArchiPacked models
    thanks guys
    Oh yeah dropdown will be better and we'll have more space to deselect components
    3D Artist - Editor
    bump
    3D Artist - Editor
    The wire color is a great idea, i'm having difficulties sometimes seing my selection.
    Mad Doctor pixelinfected's Avatar
    Jan 2004
    Santa Margherita Ligure
    614
    wireframe color is just implemeted, you select some poly, go to Detail/sketch color and choose color.
    than go to palette near the name of view, and under triangle choose color wireframe, than you see polygon selected changed with color choosed.
    LightJustice Panikos's Avatar
    Nicosia Cyprus
    1,727
    Well, it needs some more improvement since it works 5%
