Results 1 to 2 of 2
Thread: simpliest font
    simpliest font
    I made a very simple dimension tool (it writes dimensions between selected points), it works bad but ok for me....
    I'm looking for a very simple font (minimum vertex) like old plotters, just lines.
    Anybody ?
    Registered User lesterfoster's Avatar
    May 2004
    Canada, AB, Edmonton.
    815
    Can you show us a screen shot of your simple dimension tool. I use LW for rapid prototyping & reverse engineering of organic shaped objects. After figuring out the scaling issue with LW and other cad programs, I was successful.
    As where I work. We are regulated by Transport Canada, I have to provide dimensions of my models. I have been importing my models into other programs just to check the dimensions. I would rather check my dimensions from within LW.
    Just some questions
    1) is this a plug-in or a L-script?
    2) is it for modeler or layout or both?
    3) is it interactive? Meaning can I move the points around and your dimension tool well update automatically, or do I have to re-select the points and reactivate your tool to get a update?
    4) Can it do other types of dimensioning? Such as radius and diameter? As well as angles?
    5) Can it do X Y dimensioning or Z dimensioning? Or is it just a direct dimension distance from one point to another?
    6) What units does it work with? Is it unit specific or can you mix units?
    7) can you measure several points at the same time? Meaning these two points and those two points? In other words, More than just one measurement of one object?
    Quote Originally Posted by titane357
    Anybody ?
    Choose Arial or something like that. Any font
    Why not pick something more simpler than a font. Like a box or a sphere.
