Thread: png Overlay Alpha problem
    Germany
    270
    Running a DDR, we use the png format for stills. Between groups of overlays we have always used a blank png (completely transparent) as a seperator. Up until this point we have always ran them without a hitch. When highlighted in the DDR even with the DSK active, there was no overlay over the switcher signal.
    After updating to VT4.6 a couple of weeks ago, the transparent png's are now overlaying as white - no other signal is seen on the output. Going back to an overlay with content and everything is as it should be.
    Is there a setting under preferences to change this, or some other solution?
    Germany
    270
    Strange. A completely transparent png will overlay as white. The workaround is to drop a 1x1 black pixel somewhere on the frame. Then the overlay is "transparent". Go figure?!
    Does anyone have an answer for this one?
    Dec 2002
    San Antonio, TX
    3,830
    I believe it was a change in the way version 4.6 handles completely transparent images. Sorry.
    Don't stream it - TriCast it!
    TC User Group
    Minneapolis
    1,413
    Use a completely transparent RTV. Go to CG and Save Image As... RTV using a blank page.
    Ivan
