Thread: Practices for VT[4]
    Feb 2006
    Syria
    5
    Practices for VT[4]
    Hi all
    I decide to Buy VT[4] With SDI Option at next 2 months so is there any way
    to Install VT[4] Editing Software For training purposes and Where can i find
    tutorials references for Editing whit VT[4] Software.
    Sorry for bad translation
    Registered User KSTAR's Avatar
    Portland, Oregon
    526
    Currently the VT4 edit software TED as well as all of the other VT4 modules are tied to the VT4 card. So you wont be able to do any specific VT4 task until you make your purchase.
    Many people HOPE some day that TED will not be locked to the VT4 so you can edit on any machine you like
    Kevin Washington
    Portland, Oregon
    526
    Oops I forgot to answer you other question. You can get tutorials on the newtek website, and Class on demand has a few VT and Auro DVD's
    Kevin Washington
    Dec 2002
    San Antonio, TX
    3,830
    Quote Originally Posted by Noorldin
    Where can i find
    You can get started by downloading and reading the VT[4] Manual HERE
    Don't stream it - TriCast it!
    VT[5] SpeedEdit Pilot Jim Capillo's Avatar
    Gloucester, MA - The Home of the Perfect Storm
    3,048
    .....and THIS is a great place to get your questions answered !
    Jim Capillo
    CW Television Productions
    100 Cummings Center, Suite 309-G
    Beverly, MA 01915
    www.cwtvproductions.com
    Feb 2006
    Syria
    5
    Thanks all
    i need some information for the diffrent between VT[4] and VT[3] i have
    some offers for veery cheep secand hand vt[3]
    We've got it simple. Jim_C's Avatar
    Thee cool evening breezes of Anytown, USA
    4,028
    Are you doing post work or live switching? If only post, a VT3 card should suffice you well. Add another $500 us dollars on the cost of the used VT3 to upgrade the software to VT4.
    Below are some of the differences between VT3 and VT4, but note that only those with a ** next to them are specific to the VT4 card. If you do not need anything with a ** next to them, a VT3 card and a VT4 software upgrade should do you just fine.
    (Note their have been a few extra additions with the 4.6 patch that are not noted below) They can be found here: http://www.newtek.com/vt/downloads/vt46.php
    Here is a brief description of the
    TOP 40 FEATURES in VT[4]
    Real-time DV Out provides the ability to send either live or produced
    material out via FireWire cable to any compatible deck or camera. This
    option is selectable between the various VT[4] busses: Preview, Program,
    Main, or Key.
    Additional DVEs have been added to the arsenal, bringing the count to more
    than 500. With VT[4], NewTek has consolidated all DVEs, both NTSC and PAL,
    as part of a single content installation across 3 DVDs. These new DVEs are
    the highest quality transitions NewTek has ever shipped.
    Integrated Scan Conversion comes to VT[4] with the new VGA Capture utility.
    Run from the Windows Task tray, this utility can turn any windows
    application1 into a switcher input, reducing or eliminating the need for
    hardware scan conversion. Since it runs as a stand-alone application, it is
    possible to launch it and send, say, PowerPoint to video outputs without
    ever launching VT[4]. This utility allows you to zoom in to a selected
    portion of the screen, to auto-follow the mouse, to key out selected colors
    onscreen, and more.
    Automated Video Stabilization is Tool Shed's newest tool. This utility takes
    advantage of VT-Edit's real-time positioning and sizing to quickly smooth
    out video that was either hand-held or acquired from a shaky platform, such
    as through the window of a moving car or aircraft. This can be accomplished
    on either a frame or field-basis, with adjustable smoothing levels. Only
    VT[4] gives you stabilization without rendering!
    **Preview Out - is active on the VT[4] card, allowing a separate field monitor
    to always monitor the Preview bus during a live production.
    **Alpha Out is also active on VT[4], and through software, shares the Preview
    out BNC connector. This allows a VT[4] to run both CGs and the transparency
    channel to an upstream switcher.
    DVD Authoring has been added with the inclusion of ULead's DVD Workshop 2
    SE. This fully capable authoring package is integrated with VT-Edit, so you
    can drop your edited project right in for encoding and authoring, without
    the need to render out a contiguous video file first.
    MPEG-2 Encoding is now provided through DVD Workshop. It is a very simple
    process to convert your project into a compliant MPEG-2 stream for authoring
    and in the same step, burn to DVD.
    CG Post allows the creation and editing of motion CG pages directly within
    VT-Edit. Acting as a filter on the timeline, CG pages can be positioned and
    moved on either a full-page basis, or even modify the motion of each text
    line or graphic element. CG Post further offers animated kerning and
    type-out effects.
    One Button Internet Streaming uses the same high-quality windows media
    output now in an easy-to-use interface that lets you simply assign the
    quality (bandwidth) of your stream, and click one button to broadcast.
    Serverless Streaming is integrated into VT-Stream, and allows you to host up
    to 10 clients at once (bandwidth permitting) without the need for a Windows
    Media Server or ISP connection.
    Image Super-sampling provides the highest-quality real-time scaling in
    VT[4], meeting or exceeding the quality of compositing software that has to
    render to even come close to this.
    Per-layer blurring now in VT[4] allows any clip, overlay, or graphic to
    blurred horizontally or vertically. This of course can be keyframed or saved
    as a User preset to quickly apply in the future.
    Real-time Video Effects in VT-Edit include Emboss, Edges, Gaussian Blur, and
    Letter-box
    Chromakey spill suppression has been added to both the VT[4] Live Keyer and
    the real-time chroma keyer in VT-Edit. Spill suppression provides more
    sophisticated control over minimizing undesirable blue or green edging when
    pulling a key.
    New Clip border controls have been added to VT-Edit, allowing adjustment of
    the inside and outside border colors and transparency. The number of edges
    is adjustable from 3 upward, with additional controls to modify the size and
    position on all four corners
    EDL Export now added to VT[4], rounding out the data file workflow.
    Smooth shadows on keyed clips provides wonderfully soft edges and the
    shadows now conform to the shape of the keyed image. As with all other
    functions in VT-Edit, color, offset and opacity are all keyframeable.
    Improved VT Vision has been added to VT4, with a smoother image output that
    more closely resembles the video signal.
    Auto 16:9 Aspect is supported as VT[4] now looks for the 16:9 flag in video
    clips and frames the VT-Vision monitor accordingly. There are now also 16:9
    and 4:3 aspect buttons quickly accessible on the top of each VT-Vision
    monitor.
    Switcher Croutons open up a whole new capability in integrating Live and
    Post capabilities. These controls allow the VT-Edit project timeline to
    configure switcher inputs, and their status on the Preview, Aux, Main, Key
    or DSK busses. This allows VT-Edit to jump to live audio or video sources
    and back again.
    Punch in Audio support allows the editor to roll a VT-Edit project and watch
    the output while recording a narrative track straight to the timeline.
    Audio Mixer Pass-thru since it is applied "post recording", this means you
    are able to record the house mix without feedback issues from DDR audio
    already being fed to the house.
    Audio Mixer capture console is essentially an 8-channel mixer, with sliders,
    integrated in the capture panel. Tweaking levels on-the-fly is now very fast
    and easy.
    3-Band EQ of all computer sources has been added to the VT[4] audio mixer,
    allowing you bass, mid and treble control of any DDR or VT-Edit materials
    during a live switch.
    8-Band EQ in VT-Edit has been added in Control Tree and audio properties,
    allowing you keyframebale fine tone controls over all audio files in an
    edit.
    Automated Talk Over is supported in the VT[4] audio mixer, where the click
    of a single button reduces the volume all other inputs to give this channel
    priority, very handy for VJ live productions.
    Real-time audio effects have been added to VT-Edit. These include reverb,
    delay, distortion, and a flexible compressor/limiter
    Floating-point Audio provides distortion-free recording into VT[4]. There is
    now more than 10dB of headroom, meaning if the signal spikes at +3 or +6,
    the digital audio will not distort.
    Unity Gain ensures that any incoming audio will be captured and output at
    the same volume it was received.
    Calibrated Audio is available on all VT[4] audio meters throughout the
    production suite. Capture, Batch Capture, VT-Edit, DDR and Audio Mixer all
    indicate the full range with calibrated marks.
    Filebin QuickTabs make leaping between folders easier than ever, with your
    most-used favorites one click away in the bottom of any Filebin. Similar to
    the Flyer's tabs in days of yore, this provides an endless, scrollable row
    of tabs to take you to any folder on your system. Adding or removing a
    QuickTab is as easy as it was with the VT[3] Hotlist. Click. Done.
    Tally Light Support has been improved with the SX-84 breakout box. This
    offers 5 volt tally triggers, for a wider variety of hardware, and is an
    improvement over the SX-8's 3 volt signal.
    Cleaner Panel Controls are available with the ability to click and hide the
    VT-Vision or VT-Scope panel controls. The same toggle will collapse a DDR
    window to hide the files and just display the control panel.
    DDR Preview is another workflow tool. A small VT-Vision monitor on each DDR
    shows you at a glance what files are playing in each.
    Module Presets, which save your custom settings, remain on control panels,
    such as Proc Amp, Keyer and Background Generator, but each module has
    increased the preset buttons from 4 to 6.
    4-Channel Input on the VT[4] card allows input of 4 separate audio channels,
    either mic or line level. Each audio signal is selectable as mic or line in
    on the SX-84.
    Background Render has become more 'intelligent' now. Simply play through a
    multi-layer segment in your project once, and subsequent playbacks will be
    ready to print.
    **Genlock is now integrated into the VT[4] card. VT[4] can time to house synch
    with or without an SX breakout.
    **Additional Video Input through the VT[4] card now affords a third input, to
    be implemented in an upcoming patch.
