Thread: Problem adding plug-ins to Modeler
    May 2004
    California
    44
    Question Problem adding plug-ins to Modeler
    Now I've done this many times before, so unless I'm being a nuckle head and missing something, when I try to add a plug-in in Modeler it's not working.
    I go under Utilities>Add Plugins (F11), it pulls up with the window to choose which plugin I want to add. I pick which one I want, then the LW windows up that shows which plugins were found, and then I click 'Done'. But when I click under 'Additional' (under the Plug-ins) it doesn't show the plugin I just added. Anyone knows what gives? I did this the other day and it worked fine.
    Has this happened to anyone else, or am I missing something?
    Someday, I will be a CG animator.
    [URL="http://media.ccphilly.org:81/Teaching/Topical/T23_Isaiah/SAM42164.mp3"]God Is Reasonable (Isaiah 1:18) mp3 download[/URL]
    [URL="mms://media.ccphilly.org/Teaching/Topical/T23_Isaiah/SAM42124.mp3"]God Is Reasonable (Isaiah 1:18) stream[/URL]
    (only 30 minutes)
    Seeing red Kurtis's Avatar
    Feb 2004
    Bottom of the bag
    1,494
    You may know about these already, but two things to keep in mind.
    The list under Additional is not necessarily in alphabetical order. You may need to scroll all the way down.
    The name of the file does not necessarily reflect the name of the plug-in in the program.
    Kurtis Harris - NewTek 3D Marketing
    All statements to the effect of this parrot is still a going concern are from now on inoperative. This is an ex-parrot.
    May 2004
    California
    44
    What's weird, is that nothing is adding under the 'Additional' menu period. It doesn't matter what plugin I "add" nothing new shows there. The only thing there is one labeled 'FOR DividedMiddle'. ?!?
    (only 30 minutes)
