Results 1 to 2 of 2
Thread: Object replacement : help !
    May 2003
    Paris, France
    27
    Question Object replacement : help !
    I'm trying to use the Object replacement plugin to replace a ship made of 1 layer by its copy (that must partially be destroyed with a displacement plugin) made of 2 layers. (one for the crashed parts, one for the remaining parts)
    But the Obj replacement plugin only loads the first layer of the copy !
    I tried to use 2 objects each one made of 2 layers but I obtain the same results...
    Am I doing something wrong ?
    (I can't believe that the replacement plugin doesn't handle multiple layers)
    PS : each copy of the object was saved in the same subfolder with a 3 digit number "pointing" at the frame for the replacement)
    I like Polygons Rei's Avatar
    Behind you!
    477
    File, load object layer, select object, type in layer (2) and then hit return.
    I know where I'm going and I know the truth and I don't have to be what you want me to be
    I'm free to be what I want
