Thread: change only z-position
    Hi;
    1. I understand I can use commandinput "Position(x,y,z)" to change object position, but what if I only want to change z value but keep x and y value, can I use "Positon(x,y,z)" but give some mark or symbol to x and y value to keep them unchanged?or any other simple method beside use channel object agent?
    Thanks!
    Stuttgart, Germany
    13,539
    Hi zyhsu.
    I'm not that fluent in LScript, but have you tried object.Position.z = <value> ?
    ah, lightwolf, dont i wish.
    zyhsu: the solution is to get the item's current position and not to change it when you are applying the position:
    [code]
    generic
    s = Scene().firstSelect();
    pos = s.getPosition(Scene().currenttime);
    newposz = 5; // your desired z position
    Position(pos.x,pos.y,newposz);
    Stuttgart, Germany
    13,539
    Hi faulknermano,
    OT:
    see, this is why I stick to good 'ole C
    LScript might be easier to quickly hack together and check out, but somehow, I seem to be faster in C (and yes, I've read the new LScript docs... There's still lot's left to explain).
    Cheers,
    Mike
    thanks
    thanks faulknermano!
    this works!!
    z.y.hsu
    thank
    thanks LightWolf!
    I appreciate your post!
    but I think the pos.z is only for get value, not for set value!
    Z.y.hsu
