Results 1 to 2 of 2
Thread: Vanishing layers in Layout - Need help urgently!
    Hello,
    I've got to make an informal presentation tomorrow. Part of this is a real-time animation sequence that I'm putting together using basic key-frames. The secene is comprised of 8 layers, which contain around 40,000 polys. The problem I've run into is that whenever I playback the sequence, parts of it disappear. Is their anyway to remedy this? I arranged a similar scene that was equally complex earlier this year and didn't have any trouble.
    I know that if I was to render the scene then this wouldn't be a problem, but the sequence has to be in real-time so that I can zoom in/out and pan around in order to highlight certain aspects.
    If someone can help me out with this, I'd be most grateful.
    PS: I'm using v7.0
    I just found the answer here:
    http://www.newtek.com/forums/showthr...t=disappearing
    Apologies for not searching the site first. I was in a bit of a panic, you see.
    What a relief!
