Results 1 to 8 of 8
Thread: Is joint morph tool fixed in 9?
    state of confusion
    6,973
    Specifically; when making a joint morph anywhere, it records that morph to EVERY point in the model.
    It lists the morph in the info panel but has the number 0 as the amount, so there is no morph there but it lists it, so when you have a joint morph for every joint in 10 fingers and the elbow and the knees and any facial morphs used in joint morph (Like the jaw), every point has every morph listed even tho they are listed as 0.
    So a finger joint morph is listed on the foot points.
    Is there a workaround?
    currently I have to cut parts and save as a new object then make my morphs on that object, save it, then bring in and merge points with the original. This has to be done with the polys around each joint that you might need to make a morph.
    Like 30 finger joints, an elbow joint, shoulder up,down,back,and front.
    very tedious and annoying.
    Skype...lost_in_3d_space
    Sager
    I7-4800 OC'd to 3.3 GHz
    12G 1600mhz mem
    256 gigs raided SSD drive
    Untill it's fixed you might wanna use mister Fi's "Clear ZPs in All Weight Maps"
    http://flay.com/GetDetail.cfm?ID=1577
    I use it a lot, works great
    state of confusion
    6,973
    Yep,tried it and it cleans weights only, not morph 0's
    Sager
    12G 1600mhz mem
    Code Muppet evenflcw's Avatar
    Stockholm, Sweden
    2,642
    You should be able to use Cull Map set to Treshhold 0.0, and Clear Mapped activated. You'll have to do it manually for each and every morph though.
    I didn't know JointMorph showed vmaps selectivly. Never really used it. Is this in Modeler, Layout or both? Pretty nifty I think.
    state of confusion
    6,973
    shows in the point info in modeler.
    will have a go at cull map
    Sager
    12G 1600mhz mem
    Stockholm, Sweden
    2,642
    Oh sorry, I missunderstood. It was late evening/early morning when I read the initial post, so half-consious/half-asleep already. I guess reading the feature request section before this post did it's part aswell.
    state of confusion
    6,973
    YEP !!! Cull map works
    Would be nice if it didn't do it to begin with tho
    Thanks evenflcw
    Sager
    12G 1600mhz mem
    NewTek Social Media Chuck's Avatar
    Dec 2002
    San Antonio, TX
    6,364
    I've passed a link to this thread along to development, so they will be aware of these concerns!
    Chuck Baker
    Senior Manager of Communications
    NewTek.com
    LightWave3D.com
    NewTek USA Facebook
    Twitter
    LinkedIn
