Results 1 to 2 of 2
Thread: Network renderfarm VIA new Apple Ip Firewire?
    Pixel realestate agent
    n
    1,563
    Lightbulb Network renderfarm VIA new Apple Ip Firewire?
    We spoke about this a while ago waiting for Apple to release this. Now that its out even in the description is speaks about cluster abilities and suitabilities.
    Firewire means plug and play and less wires, also leaving the ethernet port for the cable modem, and sharing internet via macs with FW.
    Apple IP over firewire
    Gold Member Beamtracer's Avatar
    Citizen of the World
    2,226
    I think the main advantage of using IP over Firewire is that it is cheaper than Ethernet. A Firewire hub is cheaper than an Ethernet hub.
    I think the speed of Firewire800 is comparable to giga-Ethernet for everyday practical uses.
    A lot of Cable/DSL modems connect to the USB port (to appease the Windows crowd). If you're ever buying a high speed modem, try to get one that goes into the Ethernet or Firewire ports.
    Moral of the day:
    Worry about your own morals, not someone else's!
