Thread: Ogre Rendering Engine Problems
    LightJustice Panikos's Avatar
    Nicosia Cyprus
    1,727
    I am currently doing some 3d work for a game and the developer I am working
    with is using Ogre.
    We are currently facing some problems so I thought of asking your help.
    1. Ogre doesnt release all memory back upon quiting. I am not specialist to this,
    so if someone knows anything about it, I can bring him in contuct with the developer and find the solution.
    2. The Z axis is opposite to LW, thus the pitch works opposite too.
    Is there a recipe to translate LW mot files to ogre-world ?
    3. As far as I can realize, simple motion (position,rotation,scale) can take place easily. My developer claims that he need to add skeletons to the mesh, something I find wrong.
    Thanks for any reply.
    Oct 2005
    USA
    1,243
    I don't know what format Ogre is using but converting bones rotations ( which are in Euler angles) is not as simple as swapping coordinates ( as it is the case with mesh conversion)
    You need to write a bit more complicated code to do that.
    This link should get your coder going as far as conversion.
    http://vered.rose.utoronto.ca/people...GEMS/GEMS.html
    In fact, Lightwave SDK helper library (mocap) already contains version of the above code (MoCap/lomon_library/com_eulerangle.c and com_eulerangle.h) which is specifically geared towards use in Lightwave.
    empress incognito turbo's Avatar
    KrabbitWorld
    475
    Have you posted in the Ogre Developer Talk Forum ?
    It's pretty active.
    (We're seriously considering swapping out the torque rendering engine for the Ogre rendering engine come the new year.)
