Results 1 to 2 of 2
Thread: How to make textures follow when moving or scaling the object
    Registered User mtvedten's Avatar
    Stavanger, Norway
    35
    Question How to make textures follow when moving or scaling the object
    When I put an image map on a surface (For example putting an image in a TV-screen.) , and make it fit, it all looks OK untill I move or scale the object.
    I then have to re-adjust the texture.
    How can i make it follow the object when it is moved or scaled?
    I have used planar image maps.
    Morten
    In Modeler you can only achieve this with UV maps. In Layout there should be no problems unless you have turned on world coordinates.
    Mylenium
    [Pour Mylène, ange sur terre]
