Thread: Toaster and DV100 24P mode
    Any one know if the toaster will support The panasonci Dv100 24p frame mode?
    I mean as far as editing and playback?
    If you need some info here is a page of Links for the camera:
    http://www.mycen.com.my/dv/dvx100links.html
    Thanks,
    mike
    Bloomington, IN
    1,608
    The VT supports 24 fps avi clips now by doing a realtime 3:2 pulldown during playback. I downloaded one of the sample clips found at your link (shortflight.mov) and it is actually a 29.97 fps clip (24 fps with a 3:2 pulldown) so once converted to an avi it plays as expected. So either way it works.
    -Jeff
    My TriCaster Blog
    TriCaster Tally Lights
    VT[5] SpeedEdit Pilot Jim Capillo's Avatar
    Gloucester, MA - The Home of the Perfect Storm
    3,048
    The -100 actually has (2) 24p modes, one that does the pulldown, the other does not - it leaves it for the editing platform to perform. That's probably the question Michael is asking...... and as far as I know, it doesn't.
    Jim Capillo
    CW Television Productions
    100 Cummings Center, Suite 309-G
    Beverly, MA 01915
    www.cwtvproductions.com
    Actully I'm interested in the 24P Advanced mode.
    This one does the 2;3 conversion on the fly.
    What I'm doing is trying to get clean Plate shots for CGI stuff. The end result will be a regular video output.
    The camera only does NTSC Resolution.
    If you wanted to go to film output you would have to use a High Def camera like a Sony CineAlta or the Panasonic VariCam.
    Since I'm only grabing plates with out sound I'm not worried about lost frames or audio getting out of sync.
    I'm going to be repocessing everything through Digital Fusion or After effects anyway.
    I downloded a demo of In-syncs Blade 2.1. This wil let you grab the frames from the camera via firewire and still maintain the 24P mode.
    Mike
    Bloomington, IN
    1,608
    If you get true 24 fps AVIs into the computer, however that happens with the camcorder the VT will play them back perfectly with a VT created real-time 3:2 pull down. I have done this with animation files created in LW. If you need to output 24 fps (to go back to film etc) you need to render your timeline to a 24 fps AVI.
    -Jeff
    My TriCaster Blog
