Thread: Scaling from particles age%???
    I have 1000 particles, i need to link my obj. on each particles, and each obj. should be scale on X from particles Age%!
    How i made that???
    Thank you!
    Gaetan
    Gaetan T.
    Lead FX
    [email protected]
    www.hybride.com
    Resume / CV
    http://www.linkedin.com/in/fxgaetan
    Quote Originally Posted by gaetan
    How i made that???
    Thank you!
    Gaetan
    You write an L-Script. sorry to be of no more help, but afaik this is the only way.
    Mylenium
    [Pour Mylène, ange sur terre]
    Just thinking outloud here....
    Is it possible to create an expression in the Graph Editor that calculates the object.particlefx.size based upon the ParticleAge?
    I'm just not sure how to get that ParticleAge...
    Maybe an Expression Master will come forward with the answer.
    Somewhere, over the rainbow....
    Stuttgart, Germany
    13,543
    Try it with one object first, us FXLink in the motion panel to position it at a particles position, then use FXLink on the X Size channel of the object. It might not have the exact options you're looking for.
    If you get a result you like you can clone the objects using the FXLink Generic plugin (which also changes the particle index for the FXLink motion and channel plugins).
    Cheers,
    Mike
    Thank you for your help.
    With the FxLinker you can make a lot of things but you can't scale your obj. based upon the particle.age.
    With the Lscript fron Faulknermano call: Fx_Link_Ultra everythings work great but when a clone my obj. more than 200, the scripts stop working.
    I write an e-mail to Faulknermano about this but i have no reply.
    PLease Help
    If i can make a loop whit my particles for keeping less than 100 particles i think is a great idea!
    GT
    Gaetan T.
    Lead FX
    [email protected]
    www.hybride.com
    Resume / CV
