Thread: Multi UVs in LW possible?
    Chris Burkert
    ArchiPacked models
    Sydney
    8,273
    You can create a UV map not in 0-1 space, but can't use them separately. That is to say, you can't reference a 1-2 space separately from a 0-1 space. it will basically be as if you moved the UV's back to 0-1 space, it just makes it easier to see separate parts using the same UV areas. Or is this what you meant? Just try it and see....
    Instead of defining another UV-space then the 0-1 range you could create a weight map as an alpha channel for each UV-space. This way you can leave the UV-texture setting to tile but not affect the poly's that are in another UV-space.
    So if you're using the 0-1 UV-space, the 1-2 UV-space and the 0-3 UV-space create 3 weightmaps in which you include the poly's that are in eich UV-space and add an alpha weighmap layer on top of your texture.
    Partially Baked blabberlicious's Avatar
    Jun 2003
    London, England
    678
    :agree:
    I do that all to the time. Great for quickly patching over Seams.
    Steve Williams | d i g f r e a k | UK
    Mac: Dual 2.5GHZ G5, 2g Ram, ATi 128 OSX 10.3.7
    PC: AMD 64 X2 Dual Core +3800, Quadro FX 1300, 2 GiG Ram
