Thread: why my baking is burnt? help urgent
    Registered User jdomingo's Avatar
    Nov 2003
    perth
    320
    can anyone please help me out on how to bake illumination. (see picture) this is for our competion project a hotel resort and we are doing animation for it. i want to bake radiosity on so when i render for animation it will be fast.
    thanks
    Beyond Reality WizCraker's Avatar
    Clovis New Mexico
    1,410
    This is when FPrime comes in handy, I could never get Suface Baker to work correctly, then again last time I used it was in 6.0. Have you tried to test surface baker on something simple to see if you can identify the problem, might be a setting that you are overlooking.
    I'll try to bake something once I get done importing a protien into modeler.
    If it doesn't work look on the bright side, you can simulate the great fire of the century.
    ImageReality.com
    "Relax...it's just an update for the patch to fix the nerf that nerfed the fix for the update of the patch that broke the fix that was fixed."
    Late 2013 MacPro 12 Core
    Dreamer MooseDog's Avatar
    Mount Whoville, VT
    1,438
    are there any n-gons in the model? that will stop the baking.
    is there more than one layer to the model? that will also mess up the process.
    i forget if there's any other caveats, but good luck!
    We are pirates, we are artists...
    Blog
    Delusions of Adequacy Mebek's Avatar
    Trapped behind the Zion curtain
    183
    Kind of hard to see what's happening in that image, looks like your model is covered in spots. Are those from the radiosity bake? If so, then I'd say adjust your radiosity settings. Instead of using Interpolated, use Monte Carlo. You could also up the rays per evaluation setting - will take longer to render, but it only needs to be done once.
    --Mebek
    Nov 2003
    perth
    320
    thanks guys to all your replies.. yes i used interpolated radiosity with 4x8 ray per evaluation. no n-gons used just triangulated polys....well, another guy did the animation for this villa house in viz using the traditional way...thought i could boast out lightwave to them...better luck next time.
    thanks to all
