Thread: 3ds exporter
    Unhappy 3ds exporter
    Why all of a sudden has my 3ds exporter busted on me. I remember testing it succesfully before but now that I need it it doesn't work. Does anybody know whats up?
    Lightwave Pimp Skonk's Avatar
    Yorkshire UK
    1,450
    I cant say whats causing it but, in general closing the hub(if its open) then deleting your config files (after backing them up) and re-adding all your plugins fixes most plugin related problems.
    James..
    uh wha?
    Registered User Meaty's Avatar
    Arlington, VA
    458
    Dreamweaver, make sure your polys are tripled before you use the plug, that is usually the problem
    Chris Moschella
    Are you using the Dstorm 3DS exporter? If not it might be worth a shot;
    http://www.dstorm.co.jp/dslib/plg70e.html
    Regards,
    Terry
    Just found out today texture names for 3ds format should be 8 chars or less! try that too.
