Thread: Bright nebula is flickering in animation
    I have made a little space-animation where I have painted a nebula and placed it on a very big sheet. I have painted the center part of the nebula very bright, but that bright part is flickering and looks like a 16-bits color image in the rendered animation, it’s not looking smooth.
    I’m using one distant-light and I have excluded the nebula-object for that light.
    For the texture of nebula I have set Luminoisty to 100%.
    Anim properties:
    Resolution : 800*600
    Pixel Aspect Ratio : 1.0
    Antialiasing : High
    Video: AVI
    Compressor : Cinepack Cinema by Radius
    Texture properties:
    Resolution : 2048*1024
    Format : JPG
    The sheet with this texture is 2*1 km big in Layout.
    Anyone know why it’s flickering? Any properties to get rid of it?
    I also painted some small stars, just a white dot, and they are also flickering.
    hi ...
    I suppose that you did this video for watching on a pc (800/600):
    1) it's flickering because you use cinepack codec ( compressed ) ... Maybe too much compression (cinepack is veru destructive) , try to pack in quictime sorenson 3 (only if you want to pack.. ) if not, save your animation in motion JPEGB , you have disk space (use no compression )
    2) stars ... big problem for every one (even big studios) !!! ... Don't use a white dot (1 pixel )... use a 5 or 6 pixels stars (white spot with gradient) due to the size of your map .
    for a res of 800/600 a stars must be min: 3 or 4 pixels to not flick ...
    voilà !
    Cheers!
    Operation
    Mourad K.
    Ok, I tried Sorenson 3, it helped.
    What is "Motion JPEGB"?
    About resolution 800*600, I'm doing this animation first for PC, but later I want it for DVD/TV, suppose I will use D1 (PAL).
    Another thing about making space:
    I'm thinking about using one big skydome for the whole space instead of some sheets with nebulas, auroras and planets. I'm not sure about how big skydome and it's texture I can make. I have to make the skydome at least 250km with texturesize 2048*1024. But to give a more sharper look I'm thinking about to using the doubled size, Skydome 500 km with texture 4096*2048. But I'm not sure if that will give a more sharper looking. What do you say about that? Is it crazy and unnecessary?
