Thread: Dongle ID, where?
    Question Dongle ID, where?
    How do I find out my dongle ID?
    It's not displayed when I launch Modeler, or in the about box...
    Moving to another PC, and can't find my old license.key file
    S
    Heffalump
    Away
    3,897
    Under 7.5b at least, there's a makelicense generic layout plugin. It shows the dongle ID in that dialog.
    don't see a makelicense plugin anywhere in 7.5b... however I've found an app called getid.exe that does the job.
    Problem solved (just need my lic file form Newtek)
    ta
    S
    Key file is in your lightwave\program directory. Without it lw runs in demo mode. If that is the case call newtek for a reminder.
    Heffalump
    Away
    3,897
    Not to forget the usual reminder about notepad appending .txt to license.key - quote the file name in the save dialog of notepad (i.e. "license.key" as the filename). That should see you clear of any problems. Once you have it working, stick a copy of the .key file somewhere safe in case a future update causes problems
