Thread: A few feature requests
    Orlando, Florida
    7
    Talking A few feature requests
    Hi everyone.
    Here are a few requests, which will we good to have
    the in Lightwave 8, or in a Upgrade for 7.5 / 7.5b :
    - The Hypervoxels in the preview has to display
    correctly, there is a error, which is very disturbing,
    when working in layout.
    - It would be grat to be able to change the maximum
    hardware lights to 128.
    - When rendering a scene, Lightwave should be intelligent enough to ask (when 1/3 of the sequence is allready renderd) if you want to stop. (It's frustrating, when you accidentally pressing the esc button, after 5 hours rendering!)
    - "Pause rendering" button
    Things about Antialiasing:
    - Different antialiasing methods to choose from, like in 3DSMax.
    - One pass Antialiasing (really needed!)
    - One pass motion blur & one pass depth-of-field
    - Transparancy map preview in viewport
    - Viewport texture size not limited to 1024 but 4096
    - Faster real-time rendering (It's nearly impossible to edit 2 Million Polys!)
    - DIRECT X & OPEN GL API
    - Faster Radiosity
    - Shadow Maps for: point-,linear-and arealights.
    - Higher linear- / arealight quality (Now it's limited to 5)
    - Fade behind Objects and Fade in Fog preview in real-time
    - If possible, real-time depth-of-field & motion blur (In Camera Mode)
    - Fog affects background
    - Sub-patch support for Polygons with >4 Vertices
    - Preview in viewport when changing texture tile to mirror
    - Real-time reflections
    And I think that's what everybody wants:
    "WYSIWYG"
    What do you think about that?
    Best regards
    Wing Lung
    Live your dream, don't dream your live...ahh...sorry, model your dreams, render your live.
    what does the quality and speed of antialiasing have to do with how many passes the renderer performs?
    that sounds stupid. After render 1/3 of the sequence, the renderer suddenly asks you if you want to stop. It'll be better to just add a confirmation dialog.
    quality and speed of motion blur and depth of field has nothing to do with how many passes the renderer performs.
    buy a geforce card. Lightwave's real time render engine seems very well optimized.
    if area light uses shadow map then it wouldn't be area light.
    It's already there.
    you come up with an algorithm for that first.
    The only subdivision algorithm I know are catmull clark(4 point polys) and loop scheme (3 point polys)
    BTW, since it's mathematically provable that any polygonal surface with n-vertices can be subdivided into triangle polygons. That's why there's the triple command!
    Orlando, Florida
    7
    "that sounds stupid. After render 1/3 of the sequence, the renderer suddenly asks you if you want to stop. It'll be better to just add a confirmation dialog."
    - Sorry, I ment confirmation dialog.
    "buy a geforce card. Lightwave's real time render engine seems very well optimized."
    - I use a GeForce 4 Ti 4600 Ultra, Athlon XP 2000, 512MB DDR-2700...
    Thank's for the reply
    Best regards
    Wing lung
    voxels rule...sometimes
    I'd like some hypervoxels improvements as well:
    • blending levels for the blending mode would be nice....right now it's what LW gives you or nothing......a slider would be wonderful an user friendly.
    • if a voxel is not part of a blending group...we should be able to see that voxels
    as it passes through another voxel.
    • sprites affected by fog!......also improvements to the alpha controls for sprites....
    • textures that stick to voxels....not move through them.....I've found when morphing points around the textures don't stick.....not sure about particles with voxels applied....there may be a solution for this.....but not that i'm aware of.
    • faster rendering.......volume setting is slooooowwwww.
    • I love voxels....but I think it's been awhile since an update.
