Results 1 to 2 of 2
Thread: pivot options missing!
    Angry pivot options missing!
    hello again and thank you for your input. I tried looking for my record pivot tool and it wont find it? I scanned my directory and nothing is found? I know it is in here but what the heck? I went on another computer (im at school) and nothing! its like it has vanished off the program I dont get it! to those of you who did not see my last post I am looking for my record pivot tool (in layout) it is not located in the menu I cant find it anywhere and Im losing my mind!!!!!!!!!!!
    Setup tab, modify section, under the orientation menu. shift-p should be the shortcut. To add it to your menu, it should be under the plugins, called BT_RecPivRot. There is another record pivot rotation under the Motion menu, don't use that one. The plugin file in your LW plugins folder should be called bonetools.p. Make sure you've got the 8.2 and 8.2.1 upgrades installed.
