Results 1 to 13 of 13
Thread: Commotion Pro and VT 2
    Does anyone use Commotion Pro 4.1? Just curious if it can work with the toaster RTV files. I am looking for a better compositing capability than the one in the toaster and Commotion seems to be a good one...
    Richard
    Dec 2002
    San Antonio, TX
    3,830
    Re: Commotion Pro and VT 2
    Richard,
    My suggestion would be to investigate Eyeon's DFX+, which is an extremely mature compositor.
    Don't stream it - TriCast it!
    Austria, Europe
    9
    HEllo
    I don't like DF....
    I have commotion, but I don't use it anymore.
    I'm using combustion 2.
    Richie
    I've never used any of them in depth, but I seemed to like DF better then Combustion in the demos I saw. I've never seen commotion.
    Richie can you expand on your oppion...
    Faraz Ahmed - Amitrace
    www.Amitrace.com
    I second that. I'd like to know more about combustion. For instance, will it work on RTV files or do I have to use AVI? Is it a standalone environment or does it work with another product? Do you like their chroma key plugin and do you think it gives you great results?
    Richard
    Austria, Europe
    9
    Hello
    First of all:
    I'm working with computers since over 20 years now.
    I'm saying this, that you know, I have some imagination how things should work (and how not).
    The most of my time I'm working with LightWave and combustion.
    I'm teaching both software too (beginners).
    I saw only a demo of DF, I never worked with it.
    But I worked with A-FX, commotion pro and combustion.
    At the first open from A-FX and commotion you see many little buttons and confusing time-lines.
    I don't tuched A-FX and commotion since ~8 Months, but I was not able to write a native toaster file with commotion.
    commotion reads the file I made with combustion (it's some kind of virtual avi file).
    The quality of the composits in A-FX is terrible.
    Open combustion and you willl see something you will love.
    Clear, visible interface, big buttons also on high resolutions.
    You will find anything (settings, operators, settings for operators, and, and, and,....) you are searching for.
    Open combustion, and you will know, how to use it (like LW).
    The most AE Plugs will work in combustion but not in commotion.
    You have real-time preview in both combustion and commotion.
    With combustion I was able to read rtv files (actually I'm using combustion with Images only).
    Obviuosly it's using some kind of virtual rtv file system.
    So, I guess, you must convert your rtv's to avi, but I'm not shure, since I'm capturing with pic-videos mjpeg codec which is working without any problems.
    All 3 software packages costs ~1.000,-USD.
    DF costs much-much more.
    With combustion you can make anything you need, at the quality from the Toaster (which is very-very high).
    On other/higher professional level you should better go with other software (discreet again) but not with DF.
    I guess DF will not survive the digital revolution (like SpeedRazor, as I said before, but nobody believed me).
    Richie
    Austria, Europe
    9
    Hello
    I forgot something.
    You can download the demo of Adobe AE and discreet combustion (I'm not shure about commotion and DF).
    Try the software first.
    It's nice to see a demo, but looking what somebody doing is not the same as testing the software yourself.
    The discreet keyer is known on the whole Globe.
    It's very, very powerfull.
    We are doing many chroma and luma key (other keys too) stuff with combustion and the results are perfect.
    You really have full control over the key.
    Richie
    Very informative... Thanks... I'll look into Combustion.
    www.Amitrace.com
    We use combustion fairly regularly for the parts of our show that require more detailed post work (intros, bumpers, etc.). It's main perk for us is vector text, animated vector masks and the absolutely awesome color correction capabilities. Combustion can save out files directly to rtv, but the alpha is not saved. If you want to use alpha, you can render out a sequence of 32-bit TGAs and convert to rtv in aura.
    One sneaky problem that we've had is that combustion still uses video for windows, whereas toaster uses direct show. What this means is that combustion video files are limited to 2GB in size and that they have some flaky issues with newer direct show codecs. We finally settled on the Huffy YUV lossless codec and that seems to work pretty well on both Toaster and Combustion.
    The interface is a little nonstandard, but when you get used to how it works, it is actually quite nice.
    Regards,
    Joel Slack
    Media Department, New Life Christian Fellowship
    Newbie Member vip3dran's Avatar
    Santa Barbara, CA
    89
    Originally posted by Richie
    Hello
    Richie
    This should not be the case. It is possible something may have been set wrong. I get excellent quality composites from AFX. After Effects is a somewhat 'deep' program and takes a bit of tweaking to understand how it works and how to get the settings correct (especially when rendering your project out)
    Austria, Europe
    9
    Hello
    Here is the situation.
    I used AFX for years (the standard version).
    It shurelly worked fine and the results was very good.
    One day I got a job, that was imposible to made with the standard version of AFX.
    So I decided to purchase combustion, since the price difference between AFX Standard and Studio (or what ever it calls) was to much.
    This is the most used software in our company (after LW).
    I have a copy of AFX5.0English and commotion pro 4.1.
    If anybody needs a copy of AFX(5.0), I'll sell him mine.
    Richie
    Austria, Europe
    9
    Hello
    In some critical situation combustion is better.
    You can really believe me.
    I hope I'll get my T2 Install CD's soon....:-)
    I'll not install AFX and commotion pro on the fresh installed system anymore.
    Richie
    Stuttgart, Germany
    13,539
    Richie,
    you can get a copy of DF from www.eyeonline.com .
    I've used AE, Combustion and DF.
    Currently I stick to DF, you won't catch me dead with AE, and even combustion is something I'm not very happy with.
    Reasons:
    * Scripting
    * Expressions
    * Fastest rendering
    * Flow based
    * Network rendering (including network previews in DF 3.x, and clustering in DF 4.x).
    * Great film-based tools (if you need them)
    * Extremely good quality of the built in tools (especially basic tools like blur and scale with plenty of different algorithms to choose from).
    * Text+ rocks!
    DF has a different approach, and I see why some more graphically oriented people prefer AE or Combustion. But as a powerful, extremely flexible workhorse, DF rocks (along with shake, but that is history on the PC).
    The CMYK keyer in Combustion is quite decent, but that program is so sloooow. Rendering basic comps, DF is around 2-5 times as fast. Also, combustion until recentyl had massive problems rendering fields over the network.
    just my 2 cents...
    Cheers,
    Mike
