Results 1 to 8 of 8
Thread: l-script, envelope example
    Could somebody give me a example of using save() and load() function for envelope object agent , or tell me where I can find a example?
    Thanks!
    May 2003
    Sremski Karlovci, Serbia
    4
    Lightbulb
    You use it with
    env.load(f);
    env.save(f);
    where env is Envelope, and f is File object. Simple & clean!
    Dear Alexione:
    Thanks a lot!
    Z.Y. HSu
    Originally posted by alexione
    You use it with
    env.load(f);
    env.save(f);
    Hi!
    I try this:
    generic
    group = ChannelGroup("Face");
    ch = group.firstChannel();
    f= "c:/t1env.env";
    env.save(f);
    but get message "invalid object method", please tell me what is wrong?
    thanks!
    San Antonio, Texas, USA
    13,054
    I'm not really a coder but don't you need to declare that 'F' is a file type object, at the moment you've declared it as a string.
    UI / UX Designer @ NewTek
    Thanks for your answer!
    but I change the code to the following and make sure all
    the value exist by using info(), but it still tell me "invalid function method load"?
    generic
    info("channel: ",ch);
    file = "c:/ft-1.env";
    info("filename:",file);
    f = File(file,"r");
    info("file obj:",f);
    env.load(f);
    generic
    f = File(file,"r");
    env.load(f);
    May 2003
    4
    Just remember that env.save() and env.load() are context-sensitive - they have to be used inside save() and load() methods of your plugin.
