Results 1 to 15 of 23
Thread: Precision Modelling Question
    Question Precision Modelling Question
    Anyone,
    I am in the process of transitioning from Caligari trueSpace 6 to LightWave 3D 7.5b and I was wondering if any of you could help me with something...
    In trueSpace, there is an information panel that gives the XYZ Position, Rotation and Size for any selected point, edge, face or object based on its "axis". This allowed easy, precise modelling in the virtual 3D world.
    In LightWave, I've determined that "pivot point" is the same thing as "axis" in trueSpace. But I can't figure out how to view the information above for a poly AFTER IT HAS BEEN CREATED. I've figured out how to view/change the info for a point by using the "Info" feature. The "Info" feature doesn't show the Position, Rotation and Size for a poly.
    To give you an example of what I would use this for...
    What if I wanted an object aligned precisely with and touching the exact center of a single face on a sphere?
    I've gone thru the manual as thoroughly as possible without reading EVERY page and can't find a LightWave equivalent for what I used in trueSpace. I've grown to hate trueSpace because it is just too unstable. Please, somebody help me figure out how to do what I'm wanting in LightWave so that I don't have to switch back to that abominable trueSpace.
    Thanks,
    GuyverZ
    Well, I hate to say it, but this thing along with the inability to switch between local, world and parent space as well as the lack (more or less) snapping and alignment tools is one of the shortcomings of LW's modeler. There are a few scripts/ plugins you can find at http://www.flay.com. BTW, what do you mean with precision modelling? Even in CAD it is always pseudo-precision as long as everything is in the computer - it's all just numbers. Unless you have something in your hands there is no such thing as measurable precision.
    Mylenium
    [Pour Mylène, ange sur terre]
    Unhappy
    Hi
    That's discouraging news.
    As far as "precision", I simply mean the abilty to specify a specific point in the virtual 3D world.
    Looks like I'm not going to be able to get rid of trueSpace entirely.
    Thanks for the info.
    Thanks,
    GuyverZ
    Member Aquaman's Avatar
    Melbourne, FL. U.S.A.
    203
    You can press the "n" key for the numeric panel. This will give you the x,y,z coordinates for the object you are creating as well as their size. In modeleer the pivot point is always at 0,0,0 unless you move the pivot somewhere else via the pivot point tool. You can also use the"i" key for the info panel for both points and polygons. The info panel will number each point or poly and give its coordinates. It can be very useful for moving groups of points to the same coordiantes of another point.
    Aquaman,
    The Numeric panel only works at the time of creation. I want to find/change the XYZ position, size and rotation numerically AFTER creation. The Info panel does work for polys, but from what I've seen, it does not allow for changing the perameters mentioned above like it does for points. So those 2 features don't help me. Thanks anyway.
    Thanks,
    GuyverZ
    Mylenium
    Mylenium,
    I looked at the website you suggested to find a plugin that would work for me -- great website BTW. Unfortunately, there are so many that I'm having difficulty figuring out which one will do what I need -- especially since the details of the ones that look promising are in CHINESE. Do you know of a specific plugin that will help?
    Thanks,
    GuyverZ
    Newbie Member Tom Speed's Avatar
    Liverpool, England
    86
    Smile
    Select your Point(s), hit 'i', this bring up the Point Info panel, from there you can position any of the selected Points precisely via numerical input, or sliders.
    The Info Panel also works for Polygons, and lets you edit various information.
    Also, Points in LW don't have Rotation or Scale.
    Cya!
    Tom
    Tom,
    Thanks for the info but I don't think you understand what I'm wanting. I want to find the XYZ coordinates of a POLYGON based on what I think LW call its "normal" position or even it's "pivot point" and then change the values numerically. The "i" feature only lets me do that for POINTS--NOT POLYS.
    Caligari trueSpace can do something similar to the "i" feature in LW and it can do it for BOTH points and polys. I'm getting very frustrated that everyone keeps pointing out the "i" feature when I've already said 3 times that it does not allow you to change the position, size or rotation of a POLY -- and yes it does for points but that's not what I need.
    The model I'm working on requires precise placement of multiple "parts" based on the specific XYZ position and rotation of a POLYGON on another "part".
    I appreciate your effort in trying to help. I guess I'm going to have to keep Caligari trueSpace for modelling and use LW for rendering and animation. The problem with that is that trueSpace's boolean functions SUCK. They're completely unstable. Which is the reason I wanted to switch to LW in the first place.
    Thanks,
    GuyverZ
    Sydney
    8,273
    Do a search for normals on the flay plugin page, with modeler and free boxes ticked, that should give you something a bit more like what you want
    Vaxis mover looks good, for a start...
    Montana USA
    109
    My 0.4 cents, adjusted for inflation
    Ride the Light, it does your Aura good!
    Montana USA
    109
    Ooops, entered title and hit return
    There may be plugins that will do this, I don't know .. and like you ... searching flay is great fun, but not always productive. So then the question becomes how to do this without a plugin?
    Skimming the manual won't help ... much, read it all once, then you can skim when you have an idea what you're looking for. The stuff I'd skim for is in a section near "Align arbitrary axis" theres some stuff in there somewhere that might work with little trouble. Not having read that recently (or understood it yet) I can't say exactly what to look for, but what comes to mind:
    If you rotate your model so that the poly of interest is aligned on a known axis, then move the model to where the poly is centered on a known location, then you *know* the exact point and alignment your seeking. Granted, it's a 12 step program, but it will work without plugins.
    Sadly LW is not exactly a tool for artists, you must also be a technician, and be willing to imagine what 12 steps might be required to achieve a simple concept.
    Hope that helps.
    San Antonio, Texas, USA
    13,054
    this is why I would never use LightWave's modeler for product design, it's all geared to character modelling.
    needs a BIG update IMO.
    UI / UX Designer @ NewTek
    Montana USA
    109
    I don't know, I ve seen some good designs done in LW, but you're right it's really not designed for design. It's more generic, if you can imagine something, you can probably find a way to get it modeled.
    I agree with that, but I think the industry is in such growing pains that it's going to be rough for a long time. What worries me is that NT's code is a lot like my favorite editor's code. Small and well written, but hard to grow, so you end up relying on third party developers to take up the slack. It works, but in the long run, a codebase designed for first party growth is much better geared for the future, cause the big update comes, ready or not.
    Hastings, New Zealand
    7,731
    I dont agree that Lightwave is primarily for character modeling. Most people used Lightwave since its inception for anything but that. Characters in Lightwave are more of a recent phenomena.
    Lightwave can be precise though it depends on what you mean by precise. If you mean precision in terms of being able to manufacture something off of it then I would use something else. If you mean does it have the tools to align things to exact coordinates or orientations then the answer is yes.
    There are a variety of tools to align, rotate and move objects/polygons with respect to other objects, polygons and points either based on normals, or alignment of points and so forth. Here is one example of a tool to align an object or poly to a poly in the background.
    http://www.m2estudios.com/move_align.htm
    13,054
    accurate - points - yes, surfaces - not really
    true surfaces for manufacture - no way
    easy to implement 'product design' features (e.g. filleting, lofts, sweeps, shelling) - no way either!
    easy to draw profiles for product design features (e.g. arcs, tangency, constrained dimensions, snapping) - definately no way!
    don't get me wrong, it's a powerful modeler, you _can_ do anything in it, but for certain things (product design, man-made, hard geometric stuff etc.) it's harder to work with than freeform e.g. character stuff.
