Thread: Rendering Problem
    Rendering Problem
    As shown in the example below, I'm having strange results, lighting changing from one frame to the other, (notice the windows), this is a 1500 frames animation and the lighting changes several times. My settings are 1 area light (radiosity: interlaced, cache radiosity, 130% intensity, 3x9, ind. bounces 1, tolerance 1.0, min.evaluation spacing 100m) and two distant lights specular and shadows off (only on the distant lights) , 15% ambient intensity.
    Please I'm already behind schedule!
    Thanks in advance.
    example
    Newbie Member Calamari's Avatar
    May 2003
    Calgary, Alberta, Canada
    40
    Did you render all the frames on one machine? Sometimes when rendering the 1 anim on multiple machines 1 or more machines will output something a bit different for various reasons... If you are rendering on multiple machines I would check to see if there is any corelation between the 2 types of lighting and the machine that rendered the frames...
    You're right, I was not rendering in multiple machines, but the exact frame that occur the change was when I had to stop rendering for a while, then when I resumed it recalcuted the radiosity solution, giving me a diferent one.
    I'm no longer using radiosity in this scene (no time), but I was able to simulated well with normal lights.
    Thanks for your reply!
