Thread: Help!!!
    Exclamation Help!!!
    i am doing a spline layout but ive come to a problem. (im a begginer) see the pictire the spline that runs verticaly.. i need a point between those selected. how do i do that???
    Use Multiply / Subdivide / Add Points command!
    Visit 3D Recursions :: 3D Math for Art Places
    plus Attractors Art! and My own old and ancient Site!
    "Everyone needs something / Sometimes they don't know why / But so much good's been misunderstood / In the blink of the eye / So I take a little bad with the good / It ain't just black and white" Iggy Pop
    Lightwave Pimp Skonk's Avatar
    Yorkshire UK
    1,450
    Just to add to Exper's comment: Make sure you dont have any points selected then go into polygon mode and select the spline you want to add the points to BEFORE you try using the add points tool.
    EDIT: If you have a point selected already when you click on the spline with the add points tool it will create the new point in the same place as selected point (to create a sharp corner rather than a curve) so make sure you de-select all the points.
    uh wha?
