Results 1 to 15 of 21
Thread: Sketchy line tech inspired by SpinQuad...
    Foot in mouth wacom's Avatar
    May 2003
    Portland, OR
    1,904
    I was inspired by what I saw on SpinQuad to give a go to a "style" I've wanted to do for a while. By combin'n a few of everyone's techniques with my own I'm getting closer. I'm fairly certain I'll be able to get it to animate soon. I've included the files that produced the block image. It was made in 8.2 with PLD, but you could use 7-8 for it.
    There are two copies of a model. One is frozen and scaled up a bit and then all of the polys are tripled. I then run jitter on the frozen object (just a little bit) and then make a morph that has negative jitter values of the base object. Next I give the jittered object a seperate surface.
    In Layout I take the jittered object and turn its surface transparency all the way up, and in the object panel under render I enable edges. LW will now render the edges, but not the object. Lastly I change to fractional frames, and open the "sketch" objects morph mix panel. At zero I set it to -100 and at frame .10 or so I set it to 100. In the graph editor select each key frame and set them to oscilate (sp?). Now in the camera properties panel turn on motion blur dittered and set PLD to 3 and use the mitchel soft filter.
    The number of PLD passes, and motion blur length can change the look of the line A LOT. You can almost get a semi pencil shade if you play around with it a bit. Anyway...this was my first attempt...and it seems to work fairly well...I'm going to keep tweaking it out...
    PS- the head one was my first try at it...I change a few things for the block version and it seemed to work better (mainly how I did the jitter).
    For now here is a little demo file:
    Attached Files Attached Files
    Code Muppet evenflcw's Avatar
    Stockholm, Sweden
    2,642
    VERY nice results. That block looks just like a lead pencil drawing.
    Dreamer Ztreem's Avatar
    Jun 2003
    Sweden
    4,049
    Nice! the cube looks great. I'm looking forward to some more examples.
    I used a variation of this technique for an animated short i made a couple of months ago.
    http://vbulletin.newtek.com/showthread.php?t=31079
    That's a great idea, I like the results.
    Running at 29.97 fps Titus's Avatar
    Mexico City
    2,839
    Beatiful technique, thanks for sharing.
    Mexico City
    2,839
    A quick render using this technique:
    May 2003
    Portland, OR
    1,904
    Ok so the combo method works even better, is faster, easier to animate, and gives you 10X the flexablity! I'm playing with adding a small bit of celshader with high contrast and the diffuse turned up to get a few extra "smudgy lines"- who knows where this will go... To say I'm one happy camper is to put it lightly!
    ColinCohen's method, combined with the one I was using before (sans the jitter morph object) gets even better line draw images! I'll post a demo scene tonight after I'm back from work- here are some images. Displacement makes way more sense...
    This way is SOOO flexable...
    I'm a Registered User monovich's Avatar
    Rocky Mountain High
    1,526
    wow, this is really cool stuff, guys. I'm downloading the scene to take a look. thanks for sharing.
    Here are some otehr tests i have made. I'm using a transparent outer "skin" object with just outline active, and in the cleaner ones, an outer black flipped skin, without any outline active.
    Very very cool!! This could look fantastic animated at 12 frames per second!
    Chris Burkert
    ArchiPacked models
    3D Infant ravantra's Avatar
    Looking Over Your Shoulder
    243
    Wow you guys are amazing....I am always in awe of all the ad hoc methods to produce art that this community comes up with..... I need to find a project to try this out!
    k.no.w .... Boundaries
    May 2003
    Portland, OR
    1,904
    OK...a few new-er ones here. I'll post scene files for each one soon...sorry. I'm fairly certain that tripling the polygons and freezing the object gives slightly better lines. There are about seven or more variables to consider:
    Line width
    Displacement procedural noise size and its corolation to your mesh density
    Displacement size
    Line width
    Gradients
    Super Cell Shader
    Luminosity
    Diffuse
    Motion Blur level (must be ditthered)
    Number of PLD passes
    and even DOF for certain effects!
    These sound like a lot...but really it renders so quickly...and the setting are a bit more predictable than it would seem if you know what you're going for.
    Here are my latest examples:
    May 2003
    Portland, OR
    1,904
    And a few more...
    May 2003
    Portland, OR
    1,904
    Ok...this is the last...for now...really...
    The funny thing about these techniques is that the closer you get to their real life counterparts the more they are only good for certain things- just like the real ones!
    It's really hard to get small details in large block charcole or sumi brush ink for example...
