Thread: Strange collision object behavior
    Albuquerque, New Mexico
    24
    Has anyone else experienced strange behaviors when using Dynamic objects?
    I'm using particle emitters, collision objects, as well as a wind effector. When I remove the wind effects, or modified the particle emitters, I will over time have the collision objects stop working, or work incorrectly. This will persist even if I reload the scene, or even if I load in a new scene. The only way to get the collision objects working again is to delete the wind emitter, select the collision object and modify it in some way.
    This strange behavior seems to be an 8.2 thing. It least I cannot remember this happening in 8.0.
    Jeffrey Baker,
    Dancing Bear Graphics
    Registered User Bliz's Avatar
    Dec 2003
    London, UK
    280
    Sorry if this is obvious but are you using the FX_Start command under the SCENE menu?
    Cheers,
    Bliz::..
    My homepage
    www.anthonyrosbottom.artstation.com
    24
    No, I did not.
    When I upgraded to 8.2, my menus where once again moved. I'll have to restore to my 8.0 menu settings.
    Thanks, sometimes its obvious and sometimes it ain't
    Jeffrey Baker,
