Thread: NVIDIA Driver & Windows XP
    ****** korn_kid's Avatar
    San Fernando valley, CA
    122
    Exclamation NVIDIA Driver & Windows XP
    I just downloaded the new NVIDIA driver(v43.45), and when I went to install it I got the following message:
    So I uninstall the existing NVIDIA driver(40.41) & rebooted , and again I got the same message, so this time I just ignore it & selected yes.
    Then I got this other message:
    I selected "stop installation"(because I was worry that it might damage my system)
    Has anyone else gotten this message under Windows XP (home)SP1?
    And, should I go ahead and still install it anyway?
    system notes:
    Sony Vaio PCV-RX650
    DirectX 8
    Pentium 4
    Windows XP (Home) SP1
    01001011011011110101001001101110001000000111001001 110101011011000110010101111010
    Member Aquaman's Avatar
    Melbourne, FL. U.S.A.
    203
    This happens because Windows XP has a native(built in) driver for Nvidia video cards. Usually the best thing to do is just install the new drivers and select continue anyway when it tells you that you already have a driver installed. There are ways to get XP from installing the native driver as soon as you uninstall your current drivers and restart your system, but you have to know the exact .inf files and the core Nvidia files that are embeded in XP. It can be a pain in the but because winXP will keep driver files in multiple directories in case the files are accidently deleted it can put them back.
    Gentleman Aegis's Avatar
    The Fortesque Mansion
    1,029
    I find using nVidia's installer to update drivers under WinXP is problematic at best... Use the installer to save the driver files somewhere on your hard disk then use the Windows' Device Manager to update your drivers - far more reliable.
    "Special power!"
    Andrew G. Morgan ~ CG Gunslinger
    Survivor Films Ltd.
    London, UK
    Click here to email me!
    Budapest, Hungary
    333
    I had no problem installing ANY nvidia driver onto my XP.
    The best is of course using Detonator rip, or sg like that to remove the previous driver from registry.
    Visit www.guru3d.com for more
    Jester
    Me is me you are you,
    Who is the jackass?
    Me or you?
    203
    I knew about Detonator destroyer, but never trusted it with the new detonators because it was so old. Detonator R.I.P. looks like it is very current. I will give this one a try in the future. This will save a lot of time because I usually manually remove them which is a pain in the rear.
    122
    Thanks for the tips, I'll give it a try.
    I've never had any problems installing any of nVidias new 2000/XP drivers on my XP Pro machine. I have 41.90 right now...but I've seen a lot of stuff on the net about not going to 43.45 or whatever the new version is. but i've never had problems in the past, so I dont see how this could be a problem. any thoughts?
    Ride the wave, the Lightwave!!!
