Results 1 to 2 of 2
Thread: Camera Data--RLA Export vs. RLA Render?
    Registered User nickej's Avatar
    Rhode Island
    162
    I'm trying to do a multilayered render for export to AFX, and when I do a standard RLA sequence render from LW, AFX tells me it can't extract any camera data from the file. From my looking around this forum, I gather that, rather than just render to an RLA sequence, you have to "export" your RLAs, using some wizardry from the Image Editor panel that isn't covered in the manual (by the way, using 7.5d).
    If I try to access the Image Editor>Processing>Add Filter dropdown in the scene, it's grayed and inacessible unless I load an image or sequence. Then if I load an image, it tells me it's only for use during render, and remains inaccessible.
    How do I get camera (3D) data out of LW into AFX?
    Rhode Island
    162
    Awwww, crikey. It seems that if I want to find the answer to any question not in the manual, then all I have to do is post it here. Then I figure out the answer.
    Even if I've been stewing on it for days, somehow psting just sharpens up my wits.....well, slightly....
    Disregard that post, I've found what I needed.....
