Thread: Dongle Light not working?
    Christchruch, New Zealand
    34
    This is a problem thats been happening on and off for a while and has now become permanent. The little green light on my Dongle has stopped working but the dongle itself seems fine and Lightwave will load up fine.
    Do I need to worry about this or would it be best to get it replaced?
    Seeing red Kurtis's Avatar
    Feb 2004
    Bottom of the bag
    1,494
    mr_nebel,
    If you're not getting the "Hardware Lock Not Found" message when you open Layout or Modeler, don't worry about it. If you start getting that mssage, then you will have to contact New Magic Technical Support for an RMA to send your dongle in for repair/replacement.
    I would recommend though that you go ahead and contact them as soon as you can be without your dongle for a little bit. If that's happening, odds are its going to stop working completely at some point, and better to do it now, than to wait for a time when you've got a deadline looming and have to do it then.
    Kurtis Harris - NewTek 3D Marketing
    All statements to the effect of this parrot is still a going concern are from now on inoperative. This is an ex-parrot.
    LW Watcher
    UK
    1,485
    Kurtis, is it still the case that replacement dongles will have a different ID, or can replacement dongles have identical IDs to the returned dongle?
    Paul
    Pessac
    5,033
    Nope, replacement dongles are just that - completely new dongles. The number is generated by the dongle manufacturer, so there's no way of getting the same one again... having said that, all the major manufacturers of dongle-locked plug-ins are very understanding about dongle ID changes and respond very swiftly in my experience.
    B
    LightWave 3D Trial Edition
    Feb 2004
    Bottom of the bag
    1,494
    pauland,
    BeeVee is correct (as usual ) about Dongle IDs. He is also right about plug-in manufacturers. The most I've ever seen any of them do is to request a email or fax of a message from Customer Service confirming that you had to change your dongle. If you need one of these, contact Customer Service for your area, and they will be happy to provide that for you.
    34
    Thank you very much.
    Contacted New Magic today and i'll be sending it off tomorrow for a hopefully quick turnaround.
