Results 1 to 1 of 1
Thread: Drastically slow scene file loading time.
    Drastically slow scene file loading.
    I have a .lws scene file with more than 1000 objects. Apparently, LW taking a lot of time reading it.
    To solve the problem, I experiemnted and found that as you increase the number of objects beyond 1000, the loading time is increasing exponentially.
    A scene with 2000 objects is taking around 90 minutes to load.
    I was hoping if you people can throw some information on this issue, has everyone experienced it or something is wrong with my LW and pc ?
    Also, is it because of the memory management of the LW, it seems like LW allocates and disallocates memory for loading every object, as the number of objects increases the memory management starts taking too much time, hence the drastic loading times. Is it true ?
    What is the solution of this problem ?
    Regards,
    Arun Nager.
