Thread: Exporting animation data with lscript
    Hello all just had a question about exporting data with lscirpt
    do you have to use the montion plugin class to export animation and bone data or can this be done with a generic script
    also and pointer or advice tips trick etc.
    would be good
    thanks
    http://www.steelronin.com/index.php?...&tmenu=TMgames
    This might Help you get started. This was made to export quarternion rotation.
    Quote Originally Posted by fortress
    would be good
    thanks
    no, you dont have to use a motion plugin... motion plugins are mainly used to modify motions.. but you can extract motion data from any architecture. in your case, you want an exporter: a generic script will do fine.
    use the getPosition(), getRotation, getWorldPosition(), etc.... methods on the object agents you generate.
    thanks for the info and links guys that will help alot
