Thread: preferences
    preferences
    I want to find my preferences for LW and throw them out. I would know how to find them on a MAC, but I'm on a PC. My sliders plugin won't work and since removing and reloading the plugins didn't fix it, I'm hoping deleting the preferences will.
    Where oh where have my preferences gone?
    marvin
    Registered User Stewpot's Avatar
    West Mids England
    116
    Hi Marvin,
    What OS are you using?
    On Win 2K you will find preferences under C:\documents and settings\(and whatever user name you are.
    Hope that helps.
    Sorry about that. I'm using a PC with Win 2K pro. I went to c:\Documents and Settings\Administrator...I found some that had .cfg extensions. I had about four that started with "lw" in the name. Which should I throw out?
    Did I already say thanks, by the way? If not then thanks.
    marvin
    CORE 5718 mattclary's Avatar
    Tallahassee, Florida
    5,228
    You can get rid of all of them if you want all defaults in LightWave. Instead of deleting them, rename them or move them to another folder. That way, if you want, you can put them back.
    Michael Nicholson zapper1998's Avatar
    spokane washington usa
    4,660
    Blog Entries
    1
    Wink
    or you could create a folder in the LW Dir
    name it : Configs
    and on your short cuts for Mod, Lay, Hub
    put the [ -cD:\LightWave_3D_7.0\Configs ] minus the quotes and put a space between the .exe and the -cD of the path
    so the whole path would look like:
    D:\LightWave_3D_7.0\Programs\LightWave.exe -cD:\Lightwave_3D_7.0\Configs
    so it will access the Config file for all the Configs i did this along time ago because i got tired of searching for the darn configs
    Intel Core i7-980, OC 4.7ghz water cooled.
    Gigabyte x58-UD3R with an Intell SSD 180GIG
    RamCorsair-DDR3-1600-32GIG
    Nvidia Titan Z, x 2 And 1 GTX-1080 by Gigabyte.
    4xEnterprise/WDVelociRaptorŪ300gig
