Results 1 to 15 of 18
Thread: Dealing with computer noise
    Super Member Lew's Avatar
    Lakeland, Fl
    402
    Just got myself a new whiz-bang computer (dual xeon) to replace my ageing P4. It's great, but there's always a but. I work in a fairly small space and the fans on those xeon's are LOUD. They run fairly hot, so there's no way to cut down the fan speed without melting something (like my wallet).
    So finally, here's the questions - anyone else have the same problem? Have you made it better? Willing to share things that work or don't?
    Waiting to read, cause I can't hear -
    Lew
    VT[5] SpeedEdit Pilot Jim Capillo's Avatar
    Gloucester, MA - The Home of the Perfect Storm
    3,048
    There are a couple of water cooled solutions, as well as sound deadining enclosures......
    You're not alone - my dual Xeon sounds like a Learjet
    Jim Capillo
    CW Television Productions
    100 Cummings Center, Suite 309-G
    Beverly, MA 01915
    www.cwtvproductions.com
    Stuttgart, Germany
    13,585
    The easiest thing to do...
    replace the stock fans, they must be the loudest fans I've ever heard in my life...
    You can get some low-noise fans for roughly 15€ or so, 60mmx60mmx25mm is the size you're looking for, they should be three pin so the motherboard can control them and should do 40-60 m³/h to be on the safe side.
    I replaced mine using a bunch of Papst fans. I had to tweak the fan a bit to make the mounting holes a bit wider, but then I could just snap them on the stock coolers.
    If you want to spend some more money get different coolers.
    Depending on your case and board you could also buy 2 60mm->80mm adapters, and mount 80mm fans, they tend to be more quiet as well.
    Cheers,
    Mike
    fans
    there are fans that are quiet
    Available from MBX.com
    my machine is now quiet
    Pete
    Pete Draves
    CV Productions
    Oak Creek, WI
    [email protected]
    4,214
    I have found the Vantec Silent edition fans work great to replace the stock fans in many cases. I keep several on hand for just that reason.
    We also have installed fan controllers like from Thermaltake that allow you to monitor the temperature in the case and dynamically control the speed/noise output of the fans inside. Some of the loudest fans are the ones on the Xeon chips themselves.
    Jef Kethley
    PIZAZZ
    www.pizazz.com
    Using:
    Panasonic UB300 4k cams
    Learjet user, all i want is peace and quiet
    Registered User sbrandt's Avatar
    Back in the Moutains on the Canadian border surounded by Deer, Quail, little Bunnies, clean water, air with real oxygen, the toe-headed offspring of the pioneers who settled up here, the neighbor's Milk Cows and Jillions of tiny Chipmunks. Whoo Hoo
    794
    Start having migraines. The tinnitus will block it out!!!
    Interesting....I have dual Zeons and loud fans but I seldon hear them. They are drowned out by the cash register noise.
    Rock on T3
    If it's taking you longer than an hour to watch 60 minutes...you need help
    Lakeland, Fl
    402
    I guess I'm glad to "hear" that this is a somewhat common problem. Thanks for all the hepfull insights. Looking into some different fans, will let everyone know what happens when I change them out.
    Thanks for all the replys,
    Lew
    Stuttgart, Germany
    13,585
    Quote Originally Posted by RayLarson
    Lol, you make plenty of pennies then, ey?
    Our customers pay by money transfer, so I can hear the Xeons
    Is the Zeon a processor version for Rastafarians, yo man ?
    Cheers,
    Mike
    Jun 2003
    Edmonton, Alberta, Canada
    21
    I cut a small hole through the drywall and ran 25 ft. cables from my basement editing room into the closet of an adjoining room (utility). The tower sits in that closet on padded cement blocks. It's cool in that room and I now hear nothing from the drives or fans.
    Chris
    I take my VT with 2 lumps JReble's Avatar
    683
    Yeah, well I built a 4 foot thick cement vault in the floor of my edit room, installed my editor in it, routed my control and monitor cables through 4 1-inch conduits and poured 280lbs of concrete on top. Then I placed a thick rubber pad and hard wood floors on top. Now I don't hear my editor at all. I do keep hearing the faint sound of a beating heart coming from under the floorboards however. Wait, it's getting a little louder. Funny that it's....wait...there it is again, it's getting louder still.
    Lakeland, Fl
    402
    JReble, GET OUT! GET OUT NOW!!!
    No wait, that's just your A drive trying to find that disk you lost several years ago.
    Hope you don't have to reload anytime soon.
    794
    NEVERMORE!
    Reble, you're a funny guy!
    Sep 2004
    Pacific Northwest
    19
    Quote Originally Posted by JReble
    The tell tale hard drive, eh?
    "You should seen it; you should have seen his eye reflecting in the light!"
    "Time code is an elfin ghost that lives in your skull."
