Thread: EXPORT to DXF - crash
    When I try to export to DXF format from Modeler there is an information about error:
    DXF Export: Operation Failed - code: 1
    DXF Export: Polygons with >4 vertices not supported
    This is a shape of christmas tree and i need to export it to CAD program.
    What i should do to get it?
    rafal
    Your tree must have a polygon, or several, that have more than 3 points to a polygon, that's why it failed for you. Also check to make sure the plugin has physically been added to your plugins list.
    If your xmas tree is a tree shape made up of many points [but 1 polygon] then you will need to triple the polys to make it compatible.
    Thanks, I'll check it
    rafal
