Thread: screamernet problems
    I want to render in the background while still using Layout on a DP Mac. I've set up screamernet, but while it is rendering, I cannot access the properties window b/c it is being used by network rendering. The network rendering window does not close and cannot be replaced by either the object, bones, lights, or camera properties b/c they are not selectable. Is this how Screamernet 'works'? Am I doing something wrong?
    System specs: LW 7.5 Mac OS 10.2.4, DP 867
    suspended in Gaffa noiseboy's Avatar
    London,UK
    438
    This is what you need,
    http://www.catalystproductions.cc/screamernet/
    the ScreamerNet Controller will allow you to do exactly what you want, and its free for one Node.
    You could also use my Launch Mode3 LScript, which has less overhead for a single render on the same machine.
    http://home.earthlink.net/~mlinde/lscript.html
    "One of the things we really have to impress upon people is that it is never good to be fed on by a blood-sucking insect"
    Dr. Anthony Marfin, CDC
    Thanks a lot guys. screamernet controller helps a lot. And thanks to the author of that app.
    Does the multithreading option affect rendering 2 jobs simultaneously with a DP mac in any way? What's the best multithreading setting? I have noticed that the LWSN window won't hide when it is running, which sucks as I only have 1 monitor.
    Threading
    Threading's a really odd one. LWSN responds to threading as you'd expect but, overall, its render times seem considerably longer than Layout's. If you use multiple instances of LWSN on a single machine you should set threading to 1. This has been the recommended setup for a while. Be aware that if you set your threading higher than 1 it seems that contention between the threads with multiple LWSNs isn't worth it. Here's a rough table of what I've been getting. I always thought LWSN rendered faster than Layout (would love to know if others get similar figures).
    Layout (4 threads): 335s
    LWSN x1 (2 threads): 612s
    LWSN x1 (4 threads): 500s
    LWSN x1 (8 threads): 435s
    LWSN x2 (1 threads): 375s
    LWSN x2 (2 threads): 610s
    LWSN x2 (4 threads): 500s
    So, in Mode 2, if you have a dual machine it's a no brainer to use two instances of LWSN with the thread setting at 1. In fact if you use two instances of LWSN on a solitary dual machine with a thread setting higher than 1 you get no benefit at all. If you don't have a dual machine then the normal optimal thread settings for your scene will be appropriate. For Mode 3, the same applies. If you're running Mode 3 it looks like it would be most efficient to run two instances of the Mode 3 render instead of one with a thread setting of 1 (as with Mode 2).
    Strange that LWSN seems to render much more slowly than Layout here.
    Test Setup: 7.5OSX/DP800/10.2.4/1.5Gig RAM/Raytrace.lws/frames 1 and 2 rendered.
    Julian
