Thread: SasLite renders over holes
    Oct 2003
    UK
    98
    Ive done a search for this problem but cant seem to find it.
    Im trying to make a large field of long grass with several crossing paths of short mown grass. Im trying to se SasLite to achieve this.
    First I created a large plane and called it 'long grass'. Then I imported my paths (as in footpaths) that I created in Illustrator and used the Drill>Stencil command to create the paths on the field. I called the paths 'short grass'
    I imported this object into Layout applied SasLight and ticked the named surface only box to apply Sas to 'long grass' surface only.
    When I rendered the whole field was covered in grass including the paths. I then moved the paths to a different layer but still had the same problem. I then deleated the footpaths to leave holes in the field where the paths were yet still Sas renders even where the holes are. I can even see the black holes through the grass.
    Any ideas on what is going on here would be much appreciated. Cant afford to buy Sas full at the moment.
    Matt
    Super Member richdj's Avatar
    Dec 2003
    Nottingham, England
    552
    Matt,
    Not sure if this is any good, but have a look on this link, It's from a problem I had with saslite, which sounds a little similar, basically, it worked OK after tripling
    http://vbulletin.newtek.com/showthre...threadid=18630
    Cheers
    Rich
    Oct 2003
    UK
    98
    Thats sorted it. Thanks so much
