Thread: Compare two strings including case?
    Angry Compare two strings including case?
    I just have a quick question.
    PHP Code:
    x1="Test";
    x2="TEST";
        if (
    x1 == x2)
    info("Match!");
    Why is it when I run this, I get the 'Match" message? Since those variables are of different case, why are they considered the same? Is there something I can do to make it case sensitive?
    Go TEAM VAD!! \/
    (x1 - x2) == ""
    (x1.hash() == x2.hash())
    I was unable to find hash in the reference or user manual for lscript, so I hope you don't mind this question.
    Is .hash() akin to looking at the character codes?
    Go TEAM VAD!! \/
    patch: v1.4.5 released: 04.20.99
    A new integral object method has been added called hash(). This
    method, useful only with character strings, will return an integer
    value that represents a calculated hash value for that string. The
    array type also responds to this method, and will calculate a hash
    value for all string elements in the array.
    Cheers, thank you.
    I think that answerr'll help me a lot. I do have one more qusetion, but it's not critical to my scripting here. Couldn't this approach in rare circumstances cause a false match? I mean, if it adds the values together, couldn't you have two strings (not in the upper/lower case consideration...) that are listed as a match end up being different? Like, wouldn't "Ii" == "iI"?
    Just a point of curiosity.
    Go TEAM VAD!! \/
    yes forget this hash... I checked the return values and iI is indeed the same as Ii
    I thought it's something like MD5
    http://userpages.umbc.edu/~mabzug1/cs/md5/md5.html
    Question Are U sure ??
    Hi guys, I've the same pb.
    but.. even if there is the "new" hash() function added in the Release Notes 1.4.5 I've tried it but.... result : "Unresolved function reference: hash()"
    (in the Modeler and in the Layout).
    Why ..?
    I'm workin' on LW8.01
    But this trick :
    var1 = "MotionMixer";
    var2 = "MotionMIxer";
    if((var1 - var2) == "")
    info("Uh Oh ...! Looks like the same.");
    else
    info("Those strings are different.");
