Results 1 to 10 of 10
Thread: booldozer v2.0 for evaluation
    architectural Viz dilaima's Avatar
    lebanon
    172
    hello all again, this is the first release of booldozer, this is an evaluation copy, it still have island and exclude island under construction, and it'll expire in 7 days, anyway final release is free, hope u like it and hope some suggestions and improvement, also u can c the future developpement on:http://vbulletin.newtek.com/showthre...threadid=24728
    thank u all for ur support.
    lebanon
    172
    sorry this is the link
    u can download it here
    Attached Files Attached Files
    A few simple instructions would help.
    I made two spheres on different layers and it said to pick two polys, which ones? So I made both foreground and ran the boolean operation. It worked.
    What should I be looking for that is different than the original boolean. so far I have not seen anything new.
    It does work though
    Will play with it more
    The Dude harlan's Avatar
    Caina, Cocytus
    1,259
    Yeah, it appears that both meshes need to be on FGD - and it works with them both in the same layer as well.
    I think the concept, is more functionality, and cleaner boolean ops. It would be completely kick-*** if it had interactivity!
    Nicely done though. Can't wait to see the final release.
    harley
    "it's better to live one day as a lion, than a thousand years as a lamb."
    lebanon
    172
    grafikimon, here is a small tutorial showing how to use booldozer. sorry for the resolution, i have no fast connection to upload.
    lebanon
    172
    Stuper Member
    PA USA
    1,043
    That looks to be quite useful.
    Super Member CAClark's Avatar
    Blackburn, UK
    1,591
    It would be much more useful to write somekind of accompanying text file docs rather than the animated gif. It looks to be interesting, but please give clear docs even if it's just a single text file.
    Cheers!
    Craig A Clark
    Scorpio CGI
    My TWITTER
    lebanon
    172
    a short manual docs, final release will include a help section too.
    first lets start with the interface:
    we have 4 types of operations:
    3dboolean (as boolean)
    2dboolean (same as boolean but this one is for polygons)
    3ddrill (as solid drill)
    2ddrill (as axis drill)
    we have a different types of modes:
    A-B (operate A from B, example subtract A from B)
    --A (operate all from A)
    A-- (operate A from all)
    backup (will make a backup for the object before the operation, in
    order to do a new operation on it, or just for and undo)
    merge (will merge attached polygons after boolean, wich will give
    a cleaner boolean next time)
    continue (let the operator object selected after the operation, in order to move it or scale it.....and reboolean with it, this is to faster the workflow)
    now to start with Booldozer all u need is select 2 polygons , each
    of another object (say first poly from the box, second poly from sphere)
    the objects may be in the same layer, or in the forground of a different layer, so no need to go background and forground , and swap between the two in order to move and position.....
    Blackburn, UK
    1,591
    Thanks man
    Cheers!
    Craig A Clark
    Scorpio CGI
    My TWITTER
