Thread: Poly flip plugin
    Newbie Member j_j's Avatar
    Portland, OR
    61
    Poly flip plugin
    I have I poly heavy mesh converted from a CAD program. The problem is that some of the polys are facing the wrong way. Is there a plugin to automatically flip the polys that face the wrong way. I am dealing with several thousand polys other wise I would do it manually.
    Still a Newbie Skunk's Avatar
    Mar 2004
    Davis, California
    197
    Does 'double sided polys' double your poly count? If it doesn't.... well...
    SKUNK
    If only people with closed minds came with closed mouths, too.
    Stuper Member
    PA USA
    1,043
    The Align command is supposed to do that.
    Portland, OR
    61
    I don't think double sided will work because the model is been added to then exported to viewpoint.
    Align worked on some of the polys but not all.
    Thanks for the help.
    If it didn't flip all the polygons facing the wrong way, you might need to merge your points before using align.
