Thread: text image always backward
    why?when i apply a surface with text on it,it shows up backwards on the poly?
    also.for example-i lay out a square poly in model,single sided,front veiw and send it to layout (perspective veiw or camera) it,s facing the wrong way(away from the camera)?i thought i read about this in one of my books,but can't seem to find it. scott LW 8
    this has always bugged me.should i move the camera or rotate my model?
    Are We There Yet? bradl's Avatar
    San Antonio, Texas
    1,585
    In modeler you should always use the back view to see the 'front' of your model. There is a perfectly logical explanation for this, rooted in something to do with the positive Z axis direction, but frankly I don't remember the details. There were a bunch of discussion about that years ago on the old forums, you might want to seach there.
    Brad L.
    Thanks! i'll see if i can find that. scott
    In texture properties change angle to -180 degrees
    - SODA
    Huge Member mkiii's Avatar
    West Sussex UK
    1,102
    Or scale it -100% in X
    Everything faces the same direction by default. In other words, modeler space faces the same direction as the camera in Layout. This makes it simpler: if you model a car, you want forward motion to be positive Z. When you move the camera forward, you want that to be positive Z also.
    Confirmed -
