Results 1 to 9 of 9
Thread: point loop selection and improved bandsaw
    Newbie Member d8ed's Avatar
    San Jose, California
    73
    yeah.. point loop selection would be nice. i'm tired of having to pick points in a circle to make a polygon. it's a pain in the ***.
    also a bandsaw that works on multiple selections. so if you pick two sets of two polygons it'll use both and select/cut both. or three or four. get rid of that stupid odd or even crap and just make it required to select two polygons to define a direction. same with the point loop.
    thanks.
    George Saliba
    http://www.d8ed.com
    Definately. In my last project, I had a lot of tubes and pipes that needed extending which meant using extender or beveling. My pipes usually had 20 or more segements so it was a major paint to select all the points in order.
    73
    yeah i got spoiled for a while using XSI and the RC Tools plugin. it's got some things that made my life much easier when it came to that sort of thing. check it out.
    http://www.claus-figuren.de/rt/index.html
    and it's FREE.
    George Saliba
    http://www.d8ed.com
    Hehe, I see. But then again it works on edges to a large degree. Can we have these first, please?
    Mylenium
    [Pour Mylène, ange sur terre]
    73
    oh yeah points will do. edge support should definitely be in LW 8. it's desperately lacking. i'm crossing my fingers.
    George Saliba
    http://www.d8ed.com
    thre is a free plugin that's been around for ages called point rail selector; works like bandsaw but selects points. I think there is another one called point belt selector. check flay.com
    73
    oooh interesting.. i found this other one looking around but havent been able to test it since i'm doing a 700 frame render at the moment.. it's called FI's OEExtender that does that sort of thing regardless of point order so you can lasso around holes and extend them out. 350 frames to go!
    George Saliba
    http://www.d8ed.com
    I checked my plugins, the other one is called point belt selector. that one is slower since it is lscript but it selects points in order; if you just want to select them to move them around then use point rail selector, it's a lot faster. I'll have to check out oeextender.
    kNight Errant lord's Avatar
    tHe cavE of MontesiNos
    164
    Use the Point Rail Selector all the time, can't live without it, got a keyboard shortcut for it.
    That and Poz Extender, two tools I use together alot. Though Poz Extender hasn't been working since the updated lscript.
