Thread: Huge Vertex Paint Panel
    I somehow mangaged to resize the Vertex Paint panel in modeler larger than my Windows screen.
    The lower right corner of the vertex paint panel is unaccessable off screen so I have no way to resize the panel smaller.
    How can I reset the panel Size? I'm using LW8 on Win XP home.
    You have no way of moving or resizing the window? Can't you grab the top display window bar and drag the window until you see the BR corner? Also, you can try increasing (maybe even decrease & then increase) your o/s display size and reload Modeler/Vertex Paint and see if that enables you to grab a corner.
    Humans are pretty much monkeys with car keys.
    Unlike other windows the only way to resize the vertex paint panel is the resize icon in the lower right corner, which in my case is off the screen.
    The only way to move the panel is by grabbing the top window bar but the panel is so large that when it is moved all the way to the top of my screen there is still a good 1/3 more extended off screen.
    I'll try the screen resize but I think it will resize everything in proportion.
    Thx
    Stuper Member
    PA USA
    1,043
    I think the size of the vertex paint window is stored in the vtx3.cfg file in your user folder in documents and settings on xp.
    Thanks bloontz! That let me fix the window size and I'm good to go.
