Results 1 to 9 of 9
Thread: way to change LW OSX Interface colors?
    Hi there,
    Is there any way to change the Layout/Modeler interface colors like I've seen in Intel? I've checked the config files, and can't seem to find anything.
    Super Member PixelDust's Avatar
    West Virginia
    390
    There sure is! Try this LW interface color picker here. You need Flash 5 or up for it to work.
    The config file is called Lightwave Hub Prefs, and it should be in your Library/Preferences folder in your User folder. Just copy and paste the text into that file and save. It doesn't matter whether you actually use the Hub or not (I don't).
    Happy redecorating!
    thanks
    thanks PixelDust, works like a charm!
    Mac Addict JackDeL's Avatar
    My own little world!
    160
    Talking
    I was wondering the same thing!
    Thanks PixelDust!
    Brussels, Belgium
    105
    Originally posted by PixelDust
    ...It doesn't matter whether you actually use the Hub or not (I don't).
    To PixelDust
    This is off topic but I am curious. Why do you not use the Hub ? I always use it and it is rock solid most of the time. And I still don't know a faster way to exchange data between Modeller and Layout.
    When you test render quick modelling changes, do you always save the object file and reload it in layout ?
    Renato
    San Antonio, Texas, USA
    13,054
    i don't use it either, for me i just like to know it isn't doing anything
    odd, basically so i know exactly which version is the right model.
    silly i know but i just like a clean separation between the two!
    UI / UX Designer @ NewTek
    West Virginia
    390
    Originally posted by renatolazzaroni
    To PixelDust
    Renato
    I did use it at first, but on a couple of occasions, Layout would hang while I was working, and then if I reopened the object in Modeler, it would say that the object was read-only and I couldn't save changes.
    Fortunately, I was able to get it reopened correctly afterwards.
    Has anyone else had that happen? Are there any tricks on how to use the Hub correctly so I don't get that "read-only" error?
    Also, I've been doing the save in Modeler/reload in Layout routine. I'd like to use the Hub if I could, though.
    Brussels, Belgium
    105
    This kind of problem never happened to me, so I am afraid I can't help you much on this.
    The only hub problems I have is that it sometimes stops to synchronise Modeller and Layout, and I have to quit LW and restart it to make it work again.
    FYI, I work on MAC OS 10.2 (clean install, i.e. not upgraded from 10.1) and LW 7.5.
    Renato
    West Virginia
    390
    OK, I think I figured out what I was doing wrong. I chose "Save all objects" in Layout, instead of saving the object in Modeler, which is what I should have been doing.
    It seems to be working fine now, although it is a bit slow - I'm working on a large object (around 140,000 polys).
