Thread: What's the name of the Visual Lscript editor?
    I know I saw something about a "Visual Lscript" application once -- drag and connect components, generate Lscript code.
    I can't remember the name-- could someone remind me?
    Thanks,
    Croc
    San Antonio, Texas, USA
    13,054
    Well you could either mean LScript Commander (built into LW)
    or LScript Editor (lsed.exe - found in the 'Programs' directory in LW)
    unless there's something else out there. I had a brief look on Flay.com
    but found nothing fitting the description.
    UI / UX Designer @ NewTek
    Not Lscript commander or Editor. . .
    Hi Matt,
    . . .I looked on Flay, before posting here and didn't find anything either; but I do recall once seeing posts about a GUI-driven "drag and drop" LScript utility.
    Would be very useful. . .I like the procedural approach to things. . .something that does for modelling what Darktree does for material generation is what's on my mind. . .
    Kansas
    1,607
    The only thing I can think of is Amelie, Visual Editor
    Stuper Member
    PA USA
    1,043
    I think you are probably thinking about either Amelie which is for expressions I believe, or the new node based expression builder in LW8. There was a video that Proton posted a while back showing the nodal expression builder. I don't think there is a nodal lscript interface,
    it was Amelie
    . . .thanks for figuring out what it was I was thinking of before I did.
    The same paradigm would be usefully applied to Lscript-- could probably done on a Visio platform
